Home > Td5 > TD5 Starting problems
Page 2 of 2 <12
NickMc
You should be able to get some OBD2 data out of something cheap and cheerful? I wouldn’t spend the money on a tool as it won’t tell you too much I don’t think, especially if you’ve never used one? being honest I’d find someone local who would plug something in for you. Even a garage with a snap on tool should be able to get you the basic systems. It would be £20-45 well spent incase you buy a tool and it gives you nothing extra for a few hundred quid outlay.
If its fuel related you won’t get much out of Diagnostics, you’ll get more out of a pressure gauge. Same if it’s an electrical intermittent fault.
Have you checked the power and grounds at the sensors with a multimeter?
Post #708111 19th May 2018 7:03pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I thought mine was the crank sensor or fuel pump and had to purge the pump a few times to get it to start but also had lumpy idle. Took to independent who said he thought it was injector washers/seals which he changed and now it springs to life Very Happy .
Have you had these changed?
Also, it is getting to 70mph now whereas previously it struggled.
Post #708157 20th May 2018 5:58am
drinkdrinkdrop
Had seals and washers changed a week ago, fixed my lumpy idle but other symptoms remain
Post #708165 20th May 2018 7:52am
drinkdrinkdrop
Swapped CPS for a spare and no change. I'm getting to the point I'm fairly convinced it's a fuelling issue, sometimes when trying to coax it into life with the throttle i'll have it floored but it seems like it's only giving half revs then all of a sudden after 10-15 seconds it'll roar into life.
I'm getting 4 bar at the FPR (a hair more when cranking) I saw some suggestions of clamping the pipe from the head back to the FPR but I don't have a suitable clamp and I cant work out how to disconnect that pipe to do an inline test at that point.
Going to cut a hole in prep for cleaning out the pump filter and then probably going to be a change of pump/FPR and filter housing Sad (in some order I haven't decided on yet)
Post #708319 21st May 2018 8:49am
mk1collector
Have you had it plugged in and checked the throttle pedal signals? Ray
My build thread
Post #708331 21st May 2018 10:42am
drinkdrinkdrop
No I couldn't get any live data from the LR2, I'm not ruling that out as the cause of the revving and performance issues but as I understand it the car should still start and idle without it?
Post #708334 21st May 2018 10:46am
mk1collector
You'd think so but you seem to have ruled everything else out. Ray
My build thread
Post #708335 21st May 2018 10:48am
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
I had something similar, turned out to be the fuel pump relay burning out, not sure if you’ve changed that but if you haven’t it would be worth a try. 2005 TD5 90 CSW XS
Post #710760 4th Jun 2018 5:33pm
excossack
My 110 does similar when its has 1/4 of tank. Starts then cuts out. After a re-prime and a long crank it runs lumpy then smooths out. If I start the car and give it some revs when it has 1/4 tank the engine pulls through and drives fine.. Maybe a few extra revs might help? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #710768 4th Jun 2018 6:08pm
drinkdrinkdrop
Thanks for the suggestions
excossack as far as I can tell fuel level has no effect for me and once it's decided it's not starting priming has no effect. Occasionally having the throttle down will cause it to kinda catch then it will rev for maybe 15secs before full power turns up but 90% of the time throttle position doesn't matter
Kent_Keith I gave the relay a good clean and tested the amp draw when the pump which was running which was the same whether it started or not. Also definitely getting pressure at the regulator so pretty confident this isn't the issue but for the sack of a fiver i'll change it anyway
Right latest update, fuel pump changed, FPR changed, fuel filter housing changed, EGR blanked. Problem remains Sad
In at the local specialist for diagnostics on Thursday
Post #710853 5th Jun 2018 8:44am
drinkdrinkdrop
Just remembered, for the benefit of anyone searching this thread in the future if you have to change your fuel pump and are going in through the floor this thread was helpful http://www.defender2.net/forum/post480442.html but here are a couple of bits of advice that could be handy for other owners.
First of all I cut a round hole using a hole saw while this made getting through the floor a breeze I wouldn't recommend it for the following reason, it's way harder to get appropriate tools on the steel strengtheners below, a jig saw whipped out most of it quickly but it wasn't man enough for the taller sections and the circular access meant removing them took far longer than it should have.
If you don't know the condition of your tank locking ring before you start just buy the proper tool, a new locking ring and get the tank adapter ring ESR3807, as defenders are getting older and some like mine have been clearly parked in a swamp more than a metre deep at some point you find rust in some unusual places. My adapter ring was rotten and so seized that the tap it round with a blunt implement method just destroyed the rusty lugs and even the proper tool (when it turned up 2 days after my initial failure!) could barely get any grip on them. In the end the way it came out was jamming 2 screwdrivers through opposing holes where the lugs used to be while a helper uses the locking ring spanner to turn them, this resulted in the pump spinning along with the ring until one of the adapter ring tabs eventually snapped off and the whole lot came off together. I then removed the plastic ring from the locking ring with a hacksaw but with the snapped tab it would hold properly when I tried to reassemble
So after a few days waiting for my white adapter ring to turn up it became clear that getting it on isn't the easiest job. It's a very thick thread which starts on the right of the tank as you look at it, the thread on the ring starts next to the smaller of the 2 tabs. Line the 2 thread starts up and twist clockwise until it starts to catch. After about a quarter turn you'll think this doesn't look right as the ring will be quite "on" on one side and not close on the other, after about half a turn you'll think blimey this might snap, after about 3 quarters of a turn you will struggle to hand tighten it anymore at which point using the locking ring spanner I was able to get the extra bit of turn for the whole thread to finally catch. Now just twist it round until the thin tab sits on the right recess and the wider tab in the left recess and mount the pump and locking ring as normal
Post #710857 5th Jun 2018 9:19am
drinkdrinkdrop
Starting problem resolved Very Happy damaged wire between the alarm and ECU. So even with a 10AS disabled, breaking the LGS wire to C0658-34 will cause the immobilizer to kick in. Think I'm still down on power but will confirm over a few days and start a new thread if needed.
Thanks for all the suggestions Bow down Thumbs Up
Post #711401 8th Jun 2018 9:26am
dorsetsmith
pin 14 gray connector AS10 active low immobiliser out put ----------------------------------------------- to Co658 - pin 34 security code input to ECM need to read code being sent by immobiliser
Post #711403 8th Jun 2018 10:02am
Page 2 of 2 <12
