Home > Technical > Loose metal noise/rattle when the going gets tough
Page 2 of 2 <12
HotelCharlie
Greece 2007 Defender 110 Puma 2.4 CSW Alpine White
On my 110 Puma, I was getting a metal clicking noise on rough trails at any RPM, like metal plates vibrating against each over.
Would drive me crazy, stopping half a dozen time to check what was coming apart, to no avail.
Weeks later, while cleaning underneath the engine compartment I banged on the steering damper!! eureka, the outside sleeving tube bangs against the inner tube, so rough trail produce that sickening noise.
No harm done, and easily solved with a piece of bike inner tube. <img>
Post #207721 2nd Feb 2013 6:38pm
1ten.neuss
Germany 2008 Defender 110 Puma 2.4 SW Keswick Green
ericvv wrote:
... Sounds like could be the brake pads against the calipers...
This was indeed the case identified by the workshop crew today. Slightly press the break when travelling at a known "rattle road" and the noise is gone.
Bernd
Post #241021 4th Jun 2013 6:14pm
Innuendomaster
I get a noise you can only describe as a dull bongy spring type noise. It last for a couple of seconds, I know its not the clutch as it had a new one on Warrenty recently
Post #241040 4th Jun 2013 7:07pm
Naks
That's the TC kicking in? best described as a 'twannnng' --
Post #241163 5th Jun 2013 10:07am
bvandyk
Sounds like the springs in the clutch pressure plate that is loose. There is a recall out for that.
Post #244630 18th Jun 2013 12:55pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
I have just had this and my wheel bearings needed nipping up. All good now. Rhubarb and custard let fly with their secret weapon.
Post #245540 22nd Jun 2013 11:05am
Page 2 of 2 <12
