![]() | Home > My Defender > Baltic blue 110usw |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2158 ![]() ![]() ![]() |
Good luck -it sounds like you are making good progress and it will be better than factory when it’s done, and you’ll know every inch.
It’s a pain that the weather is not on your side - but it’ll warm up shortly👍 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17705 ![]() ![]() ![]() |
That's a bit excessive considering that the proper genuine tool from Bosch is £19.07 +VAT etc. ![]() ![]() Click image to enlarge |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 594 ![]() ![]() |
It is excessive
£20 is more like it I’ll still make one later to save waiting on delivery |
It’s back in and all connected bar one connector. I can’t for the life of me find where it goes to. It’s from the engine loom at the back by the ecu but I can’t find the connection for it. I am sure the collective knowledge on here will know
![]() Click image to enlarge ![]() Click image to enlarge |
I’m thinking I’ve got it on the wrong side of the engine. It seems dusty not oily so I’m thinking it goes along the top of the gearbox somewhere. I can’t find any reference to it online but am probably looking in the wrong place. It’s this oil and water then finished.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Along the tunnel near the gearbox you will find its partner
Thank you thank you thank you
Near or offside? I’ve been out there on my back in the rain for two hours. I thought it was down there but can’t find it. ![]() Click image to enlarge It’s not the best spot to refit an engine in the weather we have had |
Nearside https://www.lrworkshop.com/connectors/defender-2012-2.2tdci/C0448
Once again thank you Martin. Found it and connected it.
Filled with oil and coolant. Need to run it up to get the final coolant fill. Battery on charge for an attempt at starting tomorrow. Fingers crossed the epic effort in freezing weather has been worth it |
It’s running.
Got a p0100 code to start with but that was only a shonky cable above the connector. I’ve cut it off and arranged it so it works and will order a new connector. Small oil leak by filter housing to investigate and good to go |
If you need a MAF connector let me know
Thanks Martin. Already ordered as I didn’t realise you supplied these.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
Good job, and good to hear that the 2.2 is running again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Wonky vid but at least you get the idea https://youtube.com/shorts/fkrDvQYpXRI?feature=share
