Home > Wheels & Tyres > How to remove adhesive from wheel weights
Harry.O
I've recently fitted new tyres to the 110 and pulling the old adhesive balancing weights off has left a furry adhesive behind, does anyone have any suggestions on what to use to remove this?
I've tried brake cleaner and motorbike chain degreaser with a plastic scraper but neither have had much effect. I'm reluctant to use a scouring pad should it scratch the powdercoat.
Thanks, Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #697953 2nd Apr 2018 3:05pm
JOW240725
Little bit of petrol? James
Instagram @suffolk_rovers
Post #697964 2nd Apr 2018 3:20pm
V8GPC
WD40 let it soak and you can normally roll it off with your thumb (or your plastic scrapper). May leave residue behind, just more WD40 and a cloth. No damage to paint.
Post #697971 2nd Apr 2018 3:28pm
discomog
Cellulose thinners? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #697972 2nd Apr 2018 3:28pm
ericvv
Post #697973 2nd Apr 2018 3:29pm
LEZ
Yep soak with WD40 and use your credit card to scrape off.
Post #697982 2nd Apr 2018 3:51pm
Grouse
Another one for WD40 - but Petrol will work the quickest and less elbow grease required
Post #698082 2nd Apr 2018 7:18pm
JAY BOY
Wales
petrol or thinners Thumbs Up
Post #698083 2nd Apr 2018 7:19pm
Darrens110
Just WD-40 mate Thumbs Up
Post #698240 3rd Apr 2018 3:15pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
This is my go-to solution for all adhesive residues:
https://www.autoglym.com/intensive-tar-remover
Post #698286 3rd Apr 2018 6:02pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Brake cleaner definitely. I use it with a soft cotton rag to remove wheel weight adhesive. Makes the job simple and easy. I’ve done literally hundreds. Just make sure you use the bulk liquid and definitely NOT the aerosol type which IMHO is rubbish. I apply it from a pump up pressure sprayer. It’s a handy bit of kit to have it the garage as it makes short work of so many greasy/oily cleaning tasks.
Post #698343 3rd Apr 2018 8:21pm
Harry.O
Thanks all, used a combo WD40 and petrol both of which worked well but petrol was a bit quicker Thumbs Up 2005 Td5 110 Hardtop
Post #698460 4th Apr 2018 9:47am
