![]() | Home > Wheels & Tyres > How to remove adhesive from wheel weights |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Little bit of petrol? James
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
WD40 let it soak and you can normally roll it off with your thumb (or your plastic scrapper). May leave residue behind, just more WD40 and a cloth. No damage to paint.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2533 ![]() ![]() ![]() |
Cellulose thinners? Defender 90XS SW
As said. WD-40 it is.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
LEZ Member Since: 22 Oct 2015 Location: London Posts: 167 ![]() ![]() |
Yep soak with WD40 and use your credit card to scrape off.
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 524 ![]() |
Another one for WD40 - but Petrol will work the quickest and less elbow grease required
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
petrol or thinners
Darrens110 Member Since: 04 Jan 2018 Location: Staffordshire Posts: 68 ![]() ![]() |
Just WD-40 mate
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
This is my go-to solution for all adhesive residues:
https://www.autoglym.com/intensive-tar-remover |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 ![]() ![]() ![]() |
Brake cleaner definitely. I use it with a soft cotton rag to remove wheel weight adhesive. Makes the job simple and easy. I’ve done literally hundreds. Just make sure you use the bulk liquid and definitely NOT the aerosol type which IMHO is rubbish. I apply it from a pump up pressure sprayer. It’s a handy bit of kit to have it the garage as it makes short work of so many greasy/oily cleaning tasks.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Thanks all, used a combo WD40 and petrol both of which worked well but petrol was a bit quicker
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
