![]() | Home > Puma (Tdci) > Loose Passenger Door Handle |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2664 ![]() ![]() ![]() |
Hi
Take of the door fittings then remove the door card The nuts on the inside of the door handle may have come loose so you will be able to tighten them up easily Worth buying a trim removal tool as better than using a screw driver to remove the door trim from the door itself Easy job to do Good luck Mark |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Both my front door handles came loose as said above get a door trim tool as the trims are crap
considp Member Since: 22 Mar 2011 Location: Medway Posts: 5 ![]() ![]() ![]() |
Brilliant! Thanks for the advice. I'll get on the case.
Cheers Paul |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
Use loctite too and it won't happen again.
pbob Member Since: 10 Jul 2009 Location: Mudgee NSW Posts: 20 ![]() ![]() |
Yes and silly me - mine came loose and when it went in for the first service I thought it would be fixed under warranty. No.no, it along with a few other things were charged to me (at an exorbinate rate)...
Well I'd be asking why - such an item is without doubt covered by warranty. I only fixed mine because it fell off in the middle of the Gibson desert (Gunbarrel Highway!!) |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5091 ![]() ![]() ![]() |
I agree, no way should you have been charged...i had many things tightened etc under warranty Mike |
Should be no charge for that they would have done mine for me but didn't have the time to spare.
