Home > Puma (Tdci) > Loose Passenger Door Handle
considp
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi there,
Does anyone know how to tighten/refit the passenger door handle? Mine stretches away form the car about an inch when I use it!!!
Mine is a 07 Puma 110 XS SW.
Paul
Post #64858 23rd Mar 2011 5:12pm
markb110
Hi
Take of the door fittings then remove the door card
The nuts on the inside of the door handle may have come loose so you will be able to tighten them up easily
Worth buying a trim removal tool as better than using a screw driver to remove the door trim from the door itself
Easy job to do
Good luck
Mark
Post #64860 23rd Mar 2011 6:17pm
mick
Both my front door handles came loose as said above get a door trim tool as the trims are crap Thumbs Up
Post #64866 23rd Mar 2011 6:47pm
considp
Brilliant! Thanks for the advice. I'll get on the case.
Paul
Post #64871 23rd Mar 2011 7:19pm
Scallops
Australia
Use loctite too and it won't happen again.
Post #64910 24th Mar 2011 2:15am
pbob
Australia
Yes and silly me - mine came loose and when it went in for the first service I thought it would be fixed under warranty. No.no, it along with a few other things were charged to me (at an exorbinate rate)... Sad
Post #65341 27th Mar 2011 11:34pm
Scallops
Australia
Well I'd be asking why - such an item is without doubt covered by warranty. I only fixed mine because it fell off in the middle of the Gibson desert (Gunbarrel Highway!!)
Post #65345 28th Mar 2011 2:04am
mse
I agree, no way should you have been charged...i had many things tightened etc under warranty Mike
Post #65404 28th Mar 2011 6:23pm
mick
Should be no charge for that they would have done mine for me but didn't have the time to spare.
Post #65418 28th Mar 2011 7:29pm
