Home > Maintenance & Modifications > Britpart Aluminium Ladder - DA3073
Page 1 of 4 1234>
Hello folks,
Does anybody have one of these aluminium rear ladders fitted? On the face of it, they look pretty good but I can't find any detail about how the top is fixed to the body. It doesn't appear to be bolted but then also doesn't look like it hooks over the gutter Confused
 Darren
Post #695323 21st Mar 2018 10:30pm
leeds
LRA, have not seen this ladder in real life.
Normally there is a clamp on to the rain gutter which in that photo appears to be missing and there does not appear to have any holes for bolting it through top bodywork.
Conclusion? Either a pre production photograph or it is designed to hook over the gutter and be braced with the bottom two bolts. Am not sure I like that idea.
Other comment it appears to be parallel ladder. Now as that does not go around the number plate I would question if that is the correct design.
Have a look at Patriot ladders HERE They all appear to go around the number plate so I am guessing that is a legal requirement.
Brendan
Post #695331 21st Mar 2018 10:42pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Is it me or does the words Britpart and ladder together sound terrifying!! Wink Working towards Carry on camping!
Post #695340 21st Mar 2018 10:54pm
Ha, ha, you might be right!
Thanks Brendan, I didn't realise that Patriot made a gutter to chassis version. Twice the price but does look pretty good.
I've since found a description on an eBay ad that says the Britpart one does hook over the gutter but may need drilling through to secure, which is what I'm trying to avoid Rolling Eyes Darren
Post #695344 21st Mar 2018 11:13pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I have a similar style ladder but made from galv steel which just hangs off the gutter, the bottom is bolted sharing the bolts between the rear body and crossmember, that prevents it from rising up and falling off the gutter Thumbs Up
Post #695345 21st Mar 2018 11:18pm
Yeah, I had one of those, too. I just couldn't see what the top arrangement was in any pictures of the Britpart one. Darren
Post #695348 21st Mar 2018 11:21pm
leeds
For a Patriot ladder have a look here
Brendan
Post #695352 21st Mar 2018 11:33pm
wyvern
Front runner do one as well ...
http://www.frontrunneroutfitters.com/en/be...emarketing Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #695366 22nd Mar 2018 7:32am
mini Anaconda
Mine hooks over the gutter and bolts into the rear crossmember at the bottom. I sat it on a bit of foam at the top to stop any vibrations etc.
There is a small amount of movement at the top when there is no one on it, but it is solid when climbing up.
Photo below...
Thumbs Up
 BORG - Bucks & Oxon 4x4 Response Group
Post #695370 22nd Mar 2018 8:44am
That looks like the type I've had before, also mentioned by mrd1990 above. The top of the Britpart one looks quite different as it appears to sit above the gutter.
Hmm, thanks but that's not really the same thing as it still requires the body to be drilled.
Oh well, the Patriot one is probably a better solution in the long run. Thanks, all. Darren
Post #695373 22nd Mar 2018 8:59am
Brendan
What if I told you that would get you an MOT fail:
Post #695437 22nd Mar 2018 3:56pm
discomog
With more and more ANPR cameras around I'm sure that MOT testers take even more notice of partially obstructed registration plates. An obscured plate will trigger an alert if the ANPR camera cannot read the number. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #695453 22nd Mar 2018 5:09pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I don't know the regulations in the UK but here in the Netherlands it's viewed subjectively. There must be an unobstructed view but the viewing angels aren't exactly defined.
I always pass the MOT but have been pulled to the side twice by the police. No tickets though so no harm no foul Laughing a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #695455 22nd Mar 2018 5:15pm
leeds
I am sure that Paul at Hogarth Engineering has been making the Patriot ladders for long enough to know that they are legal.
I can not say the same for that Britpart ladder which is a parallel ladder which cuts across the rear number plate. That ladder would be fine on the offside of a UK vehicle.
The n/s Patriot ladder goes around the standard Defender number plate.
Conclusion?
Either not the correct Patriot or other make of ladder, something else obstructing the number plate or a MOT tester who does not know the regulations! Take your pick.
MOT testers manual section 6.3 and it is an obstruction if can not read number plate from about 20 metres away.
Brendan
Post #695462 22nd Mar 2018 6:35pm
Laurie
Cannot the numberplate be moved to the other side?
Post #695466 22nd Mar 2018 7:07pm
Page 1 of 4 1234>
