![]() | Home > Puma (Tdci) > Is this normal?? |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 330 ![]() ![]() ![]() |
Myo
The same thing has been seen in the UK, at the bottom of http://www.defender2.net/forum/topic11955-75.html is the parts diagram of the affected area. Seems like LR have been forgetting to lubricate some on assembly. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17609 ![]() ![]() ![]() |
Check both axles for backlash, worn halfshafts and drive members in the rear are common. On a 2008 Defender you probably have a two-pinion diff in the front, which will sooner or later fail. If there is mucho backlash in the front, drop the diff out to check.
If you sort out the drive train backlash you will find that the clutch and gearchange improves a lot. When sorting the clutch (and you clearly need a new one) also renew the hydraulic flow restrictor. If this is blocked it will make it very difficult to change gear smoothly. |
