Home > Maintenance & Modifications > Cruise control
Stacey007
Cruise control
OK
I've had my truck almost 3 years and one thing I do miss from previous cars is cruise control. My wifes new car even has the radar cruise which is very cleaver but got me thinking..... I may look at getting this as Europe trip again soon Smile
The kit seems to be around £300, now I'm not even going t attempt to fit this I would blow too much stuff up Smile
Do people who have cruise on a defender think its good? what should I expect to pay and auto electrician to fit?
Thanks
Post #694483 18th Mar 2018 8:03pm
Bluest
It’s great, especially if you drive on quiet French peage. It’s not as smooth as the system you get in modern cars, but it works well all the same. On mine, on some downhill gradients it can hunt a bit, like it doesn’t have enough sensitivity for very small throttle adjustments. It’s not a big problem, I usually just knock it off if it gets annoying and hit resume once back on the flat again. Really saves my ankle on level no trips.
I’ve no idea on cost to fit, I did it myself. Can’t imagine it’d be too dear as it won’t be difficult for an auto electrician. 2007 110 TDCi Station Wagon XS
Post #694484 18th Mar 2018 8:15pm
Cupboard
I have the one from Mobile Centre, it does what it says on the tin and I use it all the time.
It was pretty easy to fit, about an afternoon's work providing it's not as cold as it is at the moment!
The negatives are that it doesn't work below about 20mph and that it's not good at very low power inputs. For example when you're going down a long hill that isn't quite steep enough for gravity to do all the work, it tends to come on and off power which makes everything jolt. Once you're aware of that limitation it works well. If you're going up a steep hill and it levels off, you'll often accelerate before it realises that you don't need so much power but that's not exactly surprising.
Edit: Bluest posted whilst I was typing, it looks like we agree on its performance!
Post #694485 18th Mar 2018 8:18pm
BossHog
Best mod imho I have the same one on my 90 was great on our drive to Spain from uk, real easy to install even for a non spanner guy, good installation write up with pic's on forum by Jimz.
Post #694486 18th Mar 2018 8:19pm
Stacey007
Thanks all Thumbs Up
Was driving wife's this weekend and the radar cruise is very cleaver so I may look at this more seriously As was great Smile ok the Defender system maybe basic but as you say hour after hour on the toll roads of France Smile will be great Thumbs Up
Post #694491 18th Mar 2018 8:29pm
Have a look here - https://www.conrad-anderson.co.uk/products...se-control
From what I can see from other sites, this one offers a number of options on the stalk control which gives more memory presets.
Post #694670 19th Mar 2018 4:10pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I fitted the kit from TMD, its great, wouldn't be without it now. Very smooth operation, keeps the speed very well. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #694678 19th Mar 2018 4:38pm
I'm struggling to find out if any of the kits are fundamentally different or it's just basically the same kit available through different resellers?
Conrad Anderson state "We are the only company in the UK to import John Gold cruise control systems and can offer aftermarket cruise control kits which are suitable for use on almost any vehicle. The appropriate cruise control kit for your vehicle can be found in the list below. These are all TUV approved and extremely convenient to use, available with a steering column-mounted stalk with pre-set buttons."
If it's the latter then there's more potential in looking at the OEM website and seeing there's extra choices such as
Mounting at the center of the steering wheel with an wireless connection (RF) to the cruise control
Post #694697 19th Mar 2018 5:43pm
Stacey007
^ Is that bit pictured extra?
Post #694750 19th Mar 2018 8:31pm
seriesonenut
Looking at the site two control options on offer but not that one. Here is the optional cost controller with presets
https://www.conrad-anderson.co.uk/products/view/gc5prod 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #694758 19th Mar 2018 8:50pm
Stacey007
^ Did the same thanks,
Not sure what the above one is?
Post #694763 19th Mar 2018 9:05pm
seriesonenut
Seems to be an option over and above the standard control unit. I am also seriously thinking about having one fitted and this is the first I have seen with presets. I can see some benefit in roadworks (50mph) and so on. 2010 XS USW
Post #694768 19th Mar 2018 9:27pm
Stacey007
^ Thing is a basic stalk could actually be easier,
in a 50 zone you just click 'on' when doing 50 and away you go otherwise you have to remember what memory you have what speed set at.
It should be pretty easy with just a basic stalk? less fiddly maybe?
That company charge £180 and say 3 hours to fit which I guess is ok? I'm going to ask a car auto electrician see what they may quote?
Thanks
Post #694786 19th Mar 2018 10:01pm
I think two options have been included on the specific web page for the Defender, but other pages suggest that all of the types may be compatible with the base kit.
The CM22 steering wheel mounted command module, pictured above, is there - priced at £94.99, whereas the GC5 is on at £99.00, so notionally a slightly cheaper option.
So it looks like they have a choice of several stalks, a steering wheel option & a dash mounted option...something for everyone perhaps?
Post #694859 20th Mar 2018 8:46am
ARC99
Having had two rather scary and potentially fatal experiences with Land Rover fitted cruise control on a Mk1 Discovery I am to say the least wary of it, both incident happened on the same day and on both occasions it failed to come off when the brakes were applied. The second happening was witnessed by two Police officers in a marked patrol vehicle that was following me, when I explained after being breathalysed they prohibited the vehicle from being driven classing it as a dangerous vehicle. Land Rover were very good they recovered to the dealers , investigated the fault, repairing and arranging a suitable loan vehicle for six weeks . The dealers could not get it to disengage without pulling several fuses and Land Rover Tech's couldn't solve the problem so several new parts E.C.U., switch and a large amount of cabling were changed, they said it was sorted so I made them prove it on a airfield near York, it worked but I never trusted or used it again. Don't make old people mad.
Richard
Post #694881 20th Mar 2018 9:56am
