Home > My Defender > New addition to the family
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Well as some of you know my last 90 was written off last October.
I am pleased to introduce Albus the newest member of the family
 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #693371 14th Mar 2018 8:20pm
pj2106
2002 52 genuine county station wagon
Last owner 10 years
Genuine 82000 Miles
Pleased to be back in the gang 2008 110 2.4 XS Utility (Hagrid)
Post #693372 14th Mar 2018 8:21pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looks like a good 90 Thumbs Up more pics needed Whistle 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #693397 14th Mar 2018 9:18pm
pj2106
I will upload some more pics at the weekend I’ve been so busy I’ve not had chance 2008 110 2.4 XS Utility (Hagrid)
Post #693399 14th Mar 2018 9:19pm
L110CDL
That looks very nice, good find Thumbs Up Clayton.
Keeper.
Post #693424 14th Mar 2018 10:18pm
pj2106
A few pics now he has been cleaned
Post #697300 30th Mar 2018 7:27pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Looks great,
Enjoy Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #697302 30th Mar 2018 7:30pm
pj2106
Also now running smoothly
Replaced
Injector loom
MAF
Removed EGR
fuel filter
Cleaned intake air flow sensor soon to be an uprated one from alive
New air filter
And 2 tanks of shell expensive diesel
Will now pull cleanly in 4th upto near 70 just lacking a bit of ooopmhh in 5th soon to be unleashed by alive 2008 110 2.4 XS Utility (Hagrid)
Post #697304 30th Mar 2018 7:31pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Nice, enjoy yourself in your new toy Thumbs Up
Post #697315 30th Mar 2018 8:21pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Very nice 😎👍🏻
Stephen.
Post #697321 30th Mar 2018 8:53pm
Phil_C
2010 Defender 90 Puma 2.4 HT Galway Green
Looks lovely - but I see you have removed the EGR. You might have a problem with MOTs as I understood that from May 2018 the rules change and EGR removal is an automatic fail regardless of the emission readings. Or at least that is what my local MOT tester has told me.
Apparently they test for diesels will also involve plugging in code reader and checking all systems are working OK as well.
Hope that doesn't put a downer on it, or that I'm wrong - P 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
2010 TDCi Puma 90 HT - Bulkhead removal kit, Ashcroft front and rear lockers, Andersons front and rear, Warn XD9000i winch, battery split charge system, Patriot full roof rack. OME Suspension.
2013 Freelander II GS - Factory standard
Post #697329 30th Mar 2018 11:37pm
pj2106
Well it havingmotnext week so will be ok for another year I’ll worry about egr next year
I’ve not heard that new rule myself 2008 110 2.4 XS Utility (Hagrid)
Post #697341 31st Mar 2018 6:17am
Phil_C
I hadn't seen anything about it either, but I have removed the EGR from my TD5, the MOT tester mentioned the changes.
I mentioned it to the service manager at my local independent last week when the Freelander was serviced and he confirmed he had heard it too, but couldn't show me anything on paper.
Apparently part of the governments response to diesel emissions.
P. 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
Post #697356 31st Mar 2018 7:41am
Phil_C
Ouch - just looked it up - from the new rules effective May 2018.
8.2.2.1 Exhaust emission control equipment
You only need to check components that are visible and identifiable, such as diesel oxidation catalysts, diesel particulate filters, exhaust gas recirculation valves and selective catalytic reduction valves.
If a diesel particulate filter has clearly been cut open and rewelded, you should reject it unless the vehicle presenter can show evidence that there was a valid reason to cut it open, such as for filter cleaning.
Defect
Category
(a) Emission control equipment fitted by the manufacturer missing, obviously modified or obviously defective
Major failure
(b) An induction or exhaust leak that could affect emissions levels
Major failure
(c) Evidence that the diesel particulate filter has been tampered with
Major failure
This from
https://www.gov.uk/government/uploads/syst...-draft.pdf
Sorry to be the bearer of bad news - P 2000 TD5 Disco II, front and rear winches, 2" lift, ARB bumper etc.etc. --
Post #697357 31st Mar 2018 7:50am
