![]() | Home > Puma (Tdci) > Loose nut puma 2016 |
AdrianCR Member Since: 23 Aug 2009 Location: Costa Rica Posts: 52 ![]() ![]() |
Hello ,I have just find two loose nuts in the rear of my 110 sation wagon one on each side and I dont have a clue where they Belong. They where just behind the second row seats
Please help [/b] |
This is the exact place where I find the nuts. As before one in each side
https://ibb.co/jFecDS https://ibb.co/iipNf7 |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
I also had the extra nut in mine also
never found any missing ![]() |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
It may be worth taking off the interior trim and looking to make sure all the bolts/nuts are there securing the side body panels to the tub.
I had the same and thought nothing of it until I decided to dynomat the inside where on removing the interior trim I found the body only had one bolt/nut intact. It appeared the only thing keeping the body/roof & roof rack on the vehicle was one bolt/nut and its' self weight. Quite scary when you think about it! It worth checking if anything to make sure they are all tightened up. |
THIS.^^^ When I first took the carpet out of my mini it was like a Longbridge rubbish bin, washers, chopped off bits of cable ties all sorts under there. So it's possible they're nuts that have been dropped during manufacture, but I think the above is more likely. |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 ![]() ![]() ![]() |
I definitely agree with SMB, Flanged Nuts from the body holding down bolts more than lightly, seen this on several of my Defenders. NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
