Home > Puma (Tdci) > Loose nut puma 2016
AdrianCR
2016 Defender 110 Puma 2.4 XS CSW Scotia Grey
Loose nut puma 2016
Hello ,I have just find two loose nuts in the rear of my 110 sation wagon one on each side and I dont have a clue where they Belong. They where just behind the second row seats
Please help [/b]
Post #691859 8th Mar 2018 5:21am
AdrianCR
This is the exact place where I find the nuts. As before one in each side
https://ibb.co/jFecDS
https://ibb.co/iipNf7
Post #691860 8th Mar 2018 5:28am
Balvaig
Hopefully just spares left over during manufacture. Still have one in the chubby box which I found inside mine. Just check the obvious places for a missing nut.
Post #691880 8th Mar 2018 8:04am
steve E
Wales
I also had the extra nut in mine also
never found any missing Laughing
Post #691884 8th Mar 2018 8:50am
smb
It may be worth taking off the interior trim and looking to make sure all the bolts/nuts are there securing the side body panels to the tub.
I had the same and thought nothing of it until I decided to dynomat the inside where on removing the interior trim I found the body only had one bolt/nut intact. It appeared the only thing keeping the body/roof & roof rack on the vehicle was one bolt/nut and its' self weight. Quite scary when you think about it! It worth checking if anything to make sure they are all tightened up.
Post #691938 8th Mar 2018 12:47pm
zsd-puma
THIS.^^^
When I first took the carpet out of my mini it was like a Longbridge rubbish bin, washers, chopped off bits of cable ties all sorts under there. So it's possible they're nuts that have been dropped during manufacture, but I think the above is more likely.
Post #691968 8th Mar 2018 2:42pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
I definitely agree with SMB, Flanged Nuts from the body holding down bolts more than lightly, seen this on several of my Defenders. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #691978 8th Mar 2018 3:08pm
