Home > Maintenance & Modifications > 90 CSW - Rear seat belt bolt? |
The thread will be 7/16th UNF. I'm not sure of the exact name of these types of bolts with the wider shank but a quick trawl of eBay revealed these that would do the job:
https://www.ebay.co.uk/itm/4-x-Seat-Belt-H...SwKQ9aOj~~ Interestingly, they don't seem to be listed as a separate part in the parts book, instead coming as a package with the belts. Also, when I recently bought new, non-LR, lap belts for use in the rear of my 90, they also came with the mounting bolts. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
18th Feb 2018 8:18am |
jr1104 Member Since: 05 May 2016 Location: England Posts: 78 |
Thanks very much, that's put me in the right direction. The ones on eBay look a bit short (need to make sure the bolt gets fully threaded through the spreader plate). However, with that help I've now found Land Rover do their own seat belt fitting kit (STC1180). Ordered one of them, and will confirm if it has the correct bolt included.
Thanks again |
19th Feb 2018 7:02am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
What size are the other rear seat bolts m6x? Was going to look at mine on the weekend but didn't get a chance
19th Feb 2018 4:32pm |
You mean the ones securing the seats to the wheelboxes? Yes, typically M6. Darren
19th Feb 2018 5:31pm |
Yeah it's the length I'm not sure about? 30mm?
19th Feb 2018 5:36pm |
Probably less than that - they're only going through a couple of layers of steel/ali. In fact, when I installed two seats in mine recently, I used the shortest that I could get away with and installed them from underneath so that the threads were protected and I could put caps over them:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
19th Feb 2018 5:41pm |
Do you remember what length they were?
19th Feb 2018 6:49pm |
Can't remember, off hand. Probably either 16mm or 20mm. Darren
19th Feb 2018 7:21pm |
That sounds about right. I went with 40mm because I wanted to ensure it got through the extra soundproofing I'd added, and they're still a bit too long. 20 or 25mm is probably fine for standard fitment.
20th Feb 2018 6:29am |
Ah, I made cut-outs in my sound proofing and carpet for the seat and belt mounting points:
20th Feb 2018 7:49am |
