Home > Maintenance & Modifications > 90 CSW - Rear seat belt bolt?
jr1104
United Kingdom 1998 Defender 90 300 Tdi CSW Rioja Red
Hi everyone,
I previously removed two of the 4 inward facing rear seats, in order to give myself some more storage space. I'm now refitting these two seats (in prep for selling Sad ), but would like to replace one of the seat belt bolts as the current is a bit chewed up.
I'm likely doing a bad job of searching, but I can't find a parts list anywhere that includes these specific bolts:
It takes a 17mm socket, but doesn't seem to be a standard M10 thread. Any ideas on where I can order one from would be much appreciated!
Thanks
Post #687328 18th Feb 2018 8:07am
The thread will be 7/16th UNF. I'm not sure of the exact name of these types of bolts with the wider shank but a quick trawl of eBay revealed these that would do the job:
https://www.ebay.co.uk/itm/4-x-Seat-Belt-H...SwKQ9aOj~~
Interestingly, they don't seem to be listed as a separate part in the parts book, instead coming as a package with the belts. Also, when I recently bought new, non-LR, lap belts for use in the rear of my 90, they also came with the mounting bolts. Darren
Post #687331 18th Feb 2018 8:18am
jr1104
Thanks very much, that's put me in the right direction. The ones on eBay look a bit short (need to make sure the bolt gets fully threaded through the spreader plate). However, with that help I've now found Land Rover do their own seat belt fitting kit (STC1180). Ordered one of them, and will confirm if it has the correct bolt included.
Thanks again
Post #687513 19th Feb 2018 7:02am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
What size are the other rear seat bolts m6x? Was going to look at mine on the weekend but didn't get a chance
Post #687613 19th Feb 2018 4:32pm
You mean the ones securing the seats to the wheelboxes? Yes, typically M6. Darren
Post #687625 19th Feb 2018 5:31pm
LandymanStefan
Yeah it's the length I'm not sure about? 30mm?
Post #687627 19th Feb 2018 5:36pm
Probably less than that - they're only going through a couple of layers of steel/ali. In fact, when I installed two seats in mine recently, I used the shortest that I could get away with and installed them from underneath so that the threads were protected and I could put caps over them:
 Darren
Post #687631 19th Feb 2018 5:41pm
LandymanStefan
Do you remember what length they were?
Post #687657 19th Feb 2018 6:49pm
Can't remember, off hand. Probably either 16mm or 20mm. Darren
Post #687666 19th Feb 2018 7:21pm
jr1104
That sounds about right. I went with 40mm because I wanted to ensure it got through the extra soundproofing I'd added, and they're still a bit too long. 20 or 25mm is probably fine for standard fitment.
Post #687747 20th Feb 2018 6:29am
Ah, I made cut-outs in my sound proofing and carpet for the seat and belt mounting points:
 Darren
Post #687757 20th Feb 2018 7:49am
