Home > Puma (Tdci) > Help, can’t open my bonnet
Page 2 of 2 <12
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
mine did the same; when I got it opened I greased the mechanisms and it was fine afterwards. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #704958 3rd May 2018 8:36am
Endre
Norway 2007 Defender 110 Puma 2.4 SW Alveston Red
I have the same problem with stuck bonnet on a Puma 2007
Wire is broken and loose from handle towards front. The bonnet sits very tight and I have no idea how to open the bonnet with tools. Can someone with knowledge please PM me too. As I understand its probably the connection between the to parts of wire thats a weak point.
Post #1054803 16th Dec 2024 9:53am
spudfan
Ireland
If you put your fingers in under the bonnet between the "D" and the "E" you can just about loop them about the cable at the mechanism and pull them forward. As a safety measure for the future loop a cable tie around the cable at the latch mechanism and let it hand down behind the grill. That way if the cable snaps you can easily pull the looped cable tie and it will pop the bonnet. Happened to me.
If you do not want to replace the cable you can leave the looped cable tie in place and use that instead. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1054819 16th Dec 2024 11:40am
Endre
Cannot PM yet, but thanks alot to the one who send me a tip I will try! Smile
Post #1054823 16th Dec 2024 11:50am
spudfan
Ireland
Post #1054825 16th Dec 2024 11:55am
Endre
Sorry, have to post once more. I have a Puma 2007, and it seems need a different solution to open the bonnet, when the wire is broken.
Post #1054831 16th Dec 2024 12:14pm
spudfan
Ireland
Yes, just checked. The Puma does have stuff blocking access. Sorry about that Sad 1982 88" 2.25 diesel
Post #1054834 16th Dec 2024 12:27pm
Julie
If the bonnet lock corrodes, you'll often find the plastic lever (inside) broken and the cable being still in good condition.
Post #1054853 16th Dec 2024 3:06pm
Page 2 of 2 <12
