Home > Puma (Tdci) > Help, can’t open my bonnet |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
mine did the same; when I got it opened I greased the mechanisms and it was fine afterwards. My 90 Project : http://www.defender2.net/forum/topic52774.html
3rd May 2018 8:36am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4695 |
If you put your fingers in under the bonnet between the "D" and the "E" you can just about loop them about the cable at the mechanism and pull them forward. As a safety measure for the future loop a cable tie around the cable at the latch mechanism and let it hand down behind the grill. That way if the cable snaps you can easily pull the looped cable tie and it will pop the bonnet. Happened to me.
If you do not want to replace the cable you can leave the looped cable tie in place and use that instead. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai Last edited by spudfan on 16th Dec 2024 11:52am. Edited 1 time in total |
16th Dec 2024 11:40am |
Endre Member Since: 16 Dec 2024 Location: Larkollen Posts: 3 |
Cannot PM yet, but thanks alot to the one who send me a tip I will try!
16th Dec 2024 11:50am |
Click image to enlarge 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
16th Dec 2024 11:55am |
Sorry, have to post once more. I have a Puma 2007, and it seems need a different solution to open the bonnet, when the wire is broken.
16th Dec 2024 12:14pm |
Yes, just checked. The Puma does have stuff blocking access. Sorry about that 1982 88" 2.25 diesel
16th Dec 2024 12:27pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 496 |
If the bonnet lock corrodes, you'll often find the plastic lever (inside) broken and the cable being still in good condition. |
16th Dec 2024 3:06pm |
