Home > Puma (Tdci) > Puma 2.4 or 2.2?
Page 1 of 3 123>
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Puma 2.4 or 2.2?
Trying to determine which would be my preferred Puma; either a 2.4 or 2.2.
Could someone please let me know the main differences between them (besides the obvious engine CC and a DPF on the 2.2).
Cheers Bow down Discovery 4 HSE
Defender 2.2 110 USW XS
Ford Kuga AWD
Discovery 3
Range Rover P38
Discovery - 300 TDI
Discovery - 200TDI
Post #680531 21st Jan 2018 7:55pm
Swine&Small
2.2 is a much nicer place to be. drives better and is the choice I made following same thoughts as you
Thumbs Up Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #680536 21st Jan 2018 7:58pm
JOW240725
The 2.2 is half the road tax and lovely. Thumbs Up might be biased though and have no experience of the 2.4. James
Instagram @suffolk_rovers
Post #680539 21st Jan 2018 8:02pm
familymad
Had both. Tax is cheaper from 2010 so you can get a 2.4 in the lower bracket. Tiny bit more refined the 2.4 but has the DPF. If a keeper prob less of a concern. If you do good miles then it doesn't really matter. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #680543 21st Jan 2018 8:11pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
2.4 is easier to power chip as the 2.2 ECU has to be open up and sent off ,which just takes longer.I purchased a 2.2 as I wanted low miles and as late as possible .
Post #680552 21st Jan 2018 8:26pm
Fat Cog
I've had both...2.2 is much nicer in my opinion, can't quite put my finger on it but the 2.2 seems a tad more refined, but, being Land Rovers they're all different. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #680555 21st Jan 2018 8:29pm
JOW240725
Legin, this is no longer true. The 2.2 can now be remapped without opening the ECU Thumbs Up A local tuner said just today the 2.2 was his favourite as can be made so smooth and powerful. James
Post #680565 21st Jan 2018 8:45pm
lohr500
2.2 can be remapped through the OBD port using a remote tool available from BAS.
No need to send away or open up the ECU.
I did this on mine (150BHP) before Christmas. Not as cheap as taking it to a specialist to get the remap done, or removing and posting off the ECU, but with does have the added benefit that the vehicle can be set back to STD tune at any time using the same tool. And the tool provides other calibration functionality and error code reading.
I've had both a 2.4 and a 2.2. The 2.4 was a later model with the lower tax.
I would say the more important thing is to find a vehicle that meets your layout and general condition requirements first, rather than limiting choice by deciding on the engine.
Post #680571 21st Jan 2018 8:50pm
legin
I have about 170 BHP untested by alive tune and was told it could not be done via the OBD port ,I did not really like the idea of opening up the ECU because of water and the very fine wiring being damaged,also it took 2 weeks to send off and return.I wanted a hard top,bulk head removed,heated seats and screen and it had to be green with low mileage ,after a year of looking found my 2012 in Santorini Black all the above plus 19,000 miles and it's black ,I was going to have wrapped in Keswick Green but now 3 months on the black not so bad.So really it's about the spec more than the engine.
I did not want wing top checker plate ,which I have and still don't like Sad
Post #680585 21st Jan 2018 9:19pm
JOW240725
The ability to remap without opening ECU is relatively new, a few months maybe.
Another tuner (not BAS) described the process as follows...
"You’ve always been able to use obd you just had to patch it by getting the password from the ecu hence opening it.
Now they can calculate the password to unlock via the obd".
Thumbs Up James
Post #680593 21st Jan 2018 9:36pm
legin
Always the same I find things out after I've done it the hard way. Confused
Post #680596 21st Jan 2018 9:43pm
JOW240725
Mine was done the same way (opened ECU) I don't see it as an issue. Thumbs Up James
Post #680601 21st Jan 2018 9:47pm
My 2007 2.4 is N1 tax. Personally I would choose a 2.4 over a 2.2 any day.
Post #680622 21st Jan 2018 10:17pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Theres no replacement for displacement. Whistle
Mines also N1 for tax.
Post #680629 21st Jan 2018 10:30pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
CC= Cubes count 👍
Post #680639 21st Jan 2018 10:44pm
Page 1 of 3 123>
