Home > Puma (Tdci) > Puma 2.4 or 2.2?
Page 3 of 3 <123
zsd-puma
Really there isn't much practical difference between the two other than the DPF. Performance is virtually identical.
The 2.2 isn't just a 2.4 with 200 less CC's it does have a lot of technical changes on the engine as well as the DPF, but few of them make any noticeable difference in practice.
I went for a 2.4 just because it's better not to have a DPF for the short trips I do.
One benefit of the 2.2 is the electric lift pump, so it's easier to bleed the fuel system when you do a filter change.
Post #685445 10th Feb 2018 12:40am
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I remember reading a review of the 2.2 when it was first released and it stated the engine compartment was completely redesigned and the car had additional sound proofing over the 2.4
Post #685456 10th Feb 2018 7:18am
zsd-puma
The additional sound proofing consists of a larger plastic cover lined with foam on top of the engine.
Post #685665 10th Feb 2018 9:27pm
Page 3 of 3 <123
