![]() | Home > Maintenance & Modifications > Anyone have or fitted the Safety Devices L243 Roll Cage ? |
JJ Member Since: 18 May 2009 Location: Winchester Posts: 932 ![]() ![]() ![]() |
![]() Click image to enlarge I've got the L242 fitted to mine by a professional company and they did struggle to make it fit and still be able to open the doors as the cage pinched the body in when fitted. They got there in the end with a lot of fettling so I think your measure ( at least twice ) cut once philosophy will stand you in good stead. HR064 Hampshire and Berkshire 4x4 Response |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Good to know it is doable then! Got a big drive way and a house is being built next door, im sure i could blag a forklift & driver if needed
![]() So suggested idea is to mark everything out. Build the cage Offer up and check fitting before cutting |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2279 ![]() ![]() ![]() |
Get the front hoop assembled and fitted first, that only goes in one place and then work back from that. Use common sense and logical progression. Take your time and measure 3 times before cutting because once it's cut, it's cut. If you're not sure, stop have a cup of tea, have a think and then go back to it. Do not set a deadline to finish fitting it, it'll only make you rush, let it take as long as it takes.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Shouldnt be an isse re suspension my old 90 had a cage and drove fine with no ARBs and a small lift. The 110 has TF medium load springs + TF +2 big bore dampers (may change to OME +2s tho..) should be up to the job ![]() Im only in 3 days a week from the 12th and dont need my 110 daily so should be alright for time! |
Looking at pics it doesnt look like you can assemble just the front hoop, looks like either the whole thing or nothing |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Buy it and install it already
Im going to! Probably order it Sunday/Monday as im off week after next.
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
Stop posting pictures of roll cages, Your making me want one.
MartnH Member Since: 30 Oct 2017 Location: Nsw Posts: 28 ![]() ![]() |
this is my version of installation instructions. trust me the manual is useless. well its done in a similar fashion of Mantec manusla. only photos no words.... front cage support : -take the wing skin off, around ten bolts inside the engine bay cut rectangle shape hole on the wing skin. bolt bracket on firewall, refit wing skin. make sure the roll cage bracket stick out from the cut holes job done -middle suppot cut rectangle shape hole take the factory plate off (under B pillar.) cut it according to template fit the support bracket. job done -rear support, cut rectangle shape hole install the support brackets. its two parts. bottom part bolts on the chassis, top part in the cabin and bolted onto the bottom part while the other end stick out the cut holes. job done so up till now, you have install all the support brackets and the next step is simply put the hoops, links onto these supports brackets.... |
Thanks!
![]() Dont suppose you have ang decent pics of the middle/rear mounts? |
Ordered! From LR Direct for a very good £1330 shipped!!
Cage is arriving tomorrow, so thought I would made a start this evening!
Removed both wings in around 2hrs30. Surprisingly wasnt too difficult. Offside off, pretty simple. Removed the extended arch, snorkel and rubber inner liner (aftermarket I think, with the arches). Gave me plenty of access to all of the bolts which to my surprise where not seized in anyway. Best part is the air intake hole made for excellent access to the bulkhead/wing bolts. These came off with a 14mm socket. The rest of the surrounding bolts where 11mm. ![]() Nearside outer wing was a little more difficult to remove, took a little longer. Mainly due to the bulkhead/wing bolts which are 13.5mm heads? ![]() 13mm socket wouldnt fit, 14mm socket just span, 9/16th didnt fit either. Manged to get it off in the end by hammering a 13mm socket on ![]() ![]() ![]() Click image to enlarge Also removed about 2kg of mud!! Could anyone ID these connectors and this dohickey? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
First photo - connectors for rear washer (2 pole) and headlight levelling motor (3 pole).
Second photo - connector for alarm BBUS (if fitted). Third photo - alarm sounder (not battery backed). You seem to be missing the offside horn. |
Ahh that makes sense as its a DCPU and thus no rear jets.
Horn is there just moved for security reasons. I dont appear to have a BBSU can one be retro fitted? |
