Home > Td5 > front grill panel |
A non-aircon panel should be a direct fit. You may need a few extra bits to fir the aircon panel.
15th Jan 2018 8:16am |
Jamesy Member Since: 10 Jan 2017 Location: derbyshire Posts: 33 |
Great
would like to fit an air con version if its not to much trouble, is the difference just vents on the lower section?, and does anyone have an epson green one gathering dust they want to move on Jamesy |
15th Jan 2018 8:54am |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
The air-con grille surround sticks out further to give space for the cooling fan and gubbins for the air-con; its more box shaped. The Td5 non air-con style is flat and has the air holes to cool the oil cooler.
You would need extra brackets for the air-con type and not required; best go with the non-air-con grille; it should be a direct fit. |
15th Jan 2018 3:39pm |
Thanks for the help guys
I think I have it worked out now, Td5 non air con grill with the lower vents, then hopefully I can fit a hurricane type grill to it and get the look i'm trying to achieve Jamesy |
15th Jan 2018 4:15pm |
