Home > Td5 > front grill panel
Jamesy
front grill panel
Hi all
will a Td5 grill panel swap straight into a 300 Tdi without any modification?
Regards Jamesy
Post #678550 14th Jan 2018 11:07pm
geobloke
A non-aircon panel should be a direct fit. You may need a few extra bits to fir the aircon panel.
Post #678588 15th Jan 2018 8:16am
Jamesy
Great
would like to fit an air con version if its not to much trouble, is the difference just vents on the lower section?, and does anyone have an epson green one gathering dust they want to move on
Jamesy
Post #678605 15th Jan 2018 8:54am
V8GPC
The air-con grille surround sticks out further to give space for the cooling fan and gubbins for the air-con; its more box shaped. The Td5 non air-con style is flat and has the air holes to cool the oil cooler.
You would need extra brackets for the air-con type and not required; best go with the non-air-con grille; it should be a direct fit.
Post #678702 15th Jan 2018 3:39pm
Jamesy
Thanks for the help guys
I think I have it worked out now, Td5 non air con grill with the lower vents, then hopefully I can fit a hurricane type grill to it and get the look i'm trying to achieve
Jamesy
Post #678707 15th Jan 2018 4:15pm
