![]() | Home > My Defender > Introducing Buggsy my 110 TD5 |
Another weekend down and a load more work done;
Had loads of parcels arrive this week so have been working hard on rebuilding Buggsy, I started off with the fitting of crystal headlights and the new Halfords 150% brighter bulbs. ![]() Click image to enlarge Definitely needed the new headlight rings ![]() Whilst the headlight surrounds were off I added a little paint just to make them look a little bit more respectable; ![]() Click image to enlarge Since owning Buggsy the drives door hinge decided to fail causing the door to drop too far for even defender tolerances so a new set was ordered, with only one bolt needing to be drilled out it was an easy job. The dash is going back together and should be finished this week once a few bits from mud arrive, rude not to take advantage of the sale ![]() The engine has been run up to temp and all seems good apart from what seems to be a small weep on the heater matrix. Also got the new tyres fitted so she’s nearly good for the open road: ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Looking good, I'll have to keep my eyes peeled for you soon
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Loving this thread. You're just cracking on with it!
Cheers guys
![]() ![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10902 ![]() ![]() |
Work always comes first, then you can get on with your own
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Oh Na it’s my trailer, I’ve had the winch siting in the strap box for months and after a few too many times ratchet strapping dead vehicles onto it (Buggsy being one) and having another wagon to collect tomorrow I finally got around to fitting it. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
All good still working on your own stuff, can't beat that
![]() ![]() You bought another one ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Na don’t think I could afford another.nother one
No harm in helping a friend
You only have to look at my signiture block to know I might have a soft spot for the green and blue ovals of the motoring kind
I was thinking of that Mash
You would be richer but you would be very board with it
Very true Clayton.
So small update to day, have done a few bits but lack of pics means I will wait to write them up. Since getting the engine in and running upto temp I noticed a coolant leak from the heater matrix, so onto the internet and a few days later I had a new matrix to fit, I couldn’t justify the price difference between a normal one and the upgraded one from alisport so a normal one will go back in. ![]() Click image to enlarge ![]() Click image to enlarge With the heater box removed I noticed some surface rust so whilst it’s out I might as well treat it, I have been using neutrarust and it’s great stuff, apparently it can even be used underwater so perfect for Defenders ![]() ![]() Click image to enlarge Fingers crossed this will be the last hurdle before I can start putting some warm up miles on her prior to getting her back on the road fully, still loads of bits to do but it’s mainly luxury electrical bits and sound proofing. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
