Home > Td5 > Temprature
Page 2 of 2 <12
miker
lightning wrote:
What about removing the viscous fan coming completely? I’ve read on forums people have done this and never had the engine overheated even when towing a caravan in France in the Summer
I've seen people say the same, personally I'd never do it, seems like a pointless risk! What I might do is fit a grill muff to block some airflow. What I'll probably do is carry on wearing a coat and using the heated seats!!
I do want a webasto/eberspacher at some point though, just so I can get into a warm car in the mornings.
Post #676853 8th Jan 2018 12:12pm
grafty99
I removed my fan about 3 years ago, maybe longer and have never had a problem, even towing my parents 110 on a tri axle transporter Thumbs Up
Much less risky than actually blocking the radiator as there is still air moment Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #676855 8th Jan 2018 12:20pm
MadTom
Before removing the fan try to stop if with idling engine - with proper working viscous clutch in the fan, it is possible with one finger. ... I recommend use someone others finger for first test. Or a piece of cardboard. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #676932 8th Jan 2018 6:16pm
Laurie
My TD5's always taken around 5 miles to warm up and the temperature drops rapidly at tickover. It's the 'norm' with that engine.
Maybe that's why the XS model has a heated screen and seats..... Rolling Eyes
Post #676939 8th Jan 2018 6:28pm
UtilityTruck
On my puma the fan engages so infrequently and is so loud when it does the first few times it happened (before I’d understood what it was)I thought I’d broken something! 2014 Keswick Utility 2.2
Post #676964 8th Jan 2018 7:53pm
lightning
I have to say l have never had the heater go cold in my TD5 110 when stuck in traffic in cold weather.
Post #677277 9th Jan 2018 7:36pm
Low-Range
Canada
Before I put in an electric fan had to replace viscous fan. My vehicle definitely heated up when viscous fan failed. I replaced the 2.5 N/A with a 300tdi and went for electric, as it came with the Turner Kit. If its winter that's causing the cool down a rad muff is the answer, plus a hotter thermostat.
Post #677590 10th Jan 2018 10:53pm
annette
Costa Rica
Yes I fully agree with low range.
When I had my 109 v8 I used the same solution.
here we recommend electric fans to avoid overheating.
Viscous fans seem to pack up when it is over 50º in the sun Smile Fixing Land Rovers in rural Guanacaste
Post #679303 17th Jan 2018 4:55pm
atakanmerdin
Kenya
Remove fan??? What??? How???
Not here in Kenya... a dead fan cost me a new head...
With OEM borg Warner viscous I now barely get above 73C on normal running, can barely get it to high 90C on hard runs. Monitor temps and other readings via MDMAN EMS.
Post #684705 7th Feb 2018 5:40am
OlavLRD110
Estonia 2003 Defender 110 Td5 CSW Baltic Blue
Fan removed 3 years ago.In summer temp max85..88C (installed Omron temp controller) even in traffic jam.
In winter warmed up faster. For winter Webasto and Defa Warm Up. TD5 coolingsystem is owersaised.
Post #685188 9th Feb 2018 5:43am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I go off-road and even with a good working visc. fan I managed to get it in the red zone a few times. With full throttle spinning 35"Simexes the heat builds up. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #685205 9th Feb 2018 7:51am
Page 2 of 2 <12
