Home > Td5 > Temprature
TJH1985
Temprature
Hi All,
In the recent cold(ish) weather we have noticed that when idle I.e stuck in traffic my coolant temperatures are dropping off to the lower end of the gauge and we loose heat from the heaters. When back on the move coolant temprature rises and heaters return.
Before I start investigating, and most likely changeing the thermostat, is this normal? I assume it’s a viscous fan, should it be fully disengaged when coolant temps are low, maybe it’s running full chat even when I’m idling.
Advice greatly appreciated Mr. Green
Thanks,
Tom
Post #674603 31st Dec 2017 9:04am
4RF RDS
Depending how cold and how long at idle, it is VERY normal. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #674958 1st Jan 2018 3:03pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
The viscous fan is rather effective and will cool the engine if sat at tick over.
Post #674960 1st Jan 2018 3:13pm
Retroanaconda
Only if it is faulty Rolling Eyes
On a cold engine the viscous will be free-wheeling, that is to say it will be turning but not at engine RPM and with no force behind it, able to be stopped by a rolled up newspaper or a gloved hand. The airflow generated will be minimal and will not cool the engine significantly.
The heater will draw heat from the cooling system and this will be enough to cool the engine at idle if you sit for long enough. However it is far more likely that your thermostat is faulty and the coolant is still being circulated through the rad, which leads to overcooling.
Post #675111 2nd Jan 2018 10:13am
MadTom
In warm weather, when the viscous fan fully "engages" it sound like a starting helicopter. You can hear it also in car. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #675120 2nd Jan 2018 11:12am
miker
I'd disagree, mines perfectly easy to stop when cold, and spins freely enough when the engine is off. It still shifts a fair bit of air even at idle! I also have a new thermostat, and the engine will not stay warm in traffic in the winter. Radiator bottom hose stays nicely cool.
Post #675204 2nd Jan 2018 6:22pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
I am experiencing the very same symptoms
Glad to hear that the general consensus is that this is normal for the time of year Shocked
G My confidence has been writing cheques that my abilities can't cash for years.
Post #675215 2nd Jan 2018 7:25pm
geobloke
Hi Tom. This is entirely normal and something that is incredibl frustrating when you have a cold wife sitting next to you...
One solution is heated seats, the second is an auxiliary diesel heater.
Love TD5s... Thumbs Up Thumbs Up
Post #675231 2nd Jan 2018 8:11pm
Lou Sparts
Mines the same, viscous fan o.k new thermostat fitted when I noticed this the first winter I owned it. Heater adequate other than this. As mentioned above heated seats go some way to compensating. 2005 Td5 90 XS
Steve
Post #675249 2nd Jan 2018 8:50pm
geobloke
Although it does take a little getting used to the hot bum and cold tops of your thighs.... Mr. Green Mr. Green
Post #675270 2nd Jan 2018 9:50pm
TJH1985
Thanks guys, this all makes allot of sense.. I’m going to give it the once over to be certain.
@geobloke this that’s my primary issue a cold other half, who usually drives a nice FFRR complete with fuel based heater, climate seats and heated steering wheel she ain’t impressed with the Defender or my obsession with takeing it out at the first sign of snow Rolling with laughter
Looks like the thermostat should open at 82C so a fairly easy one to check.
Post #675288 2nd Jan 2018 11:11pm
geobloke
Priorities priorities... It is the key to a happy life with a Defender... My next priority is a gas rear strut for the rear door... Thumbs Up
Thermostat is easy enough to test off the vehicle, a bit of a pain to get out but it would be a great time to chemically flush your system and replace the coolant.
In the last few months I have had to (courtesy of a warped head) replace the radiator, hoses and thermostat on my TD5 and I can tell you it heats up quicker now, but also cools down very quickly too. Big Cry Hebce starting this thread on auxiliary heaters before Christmas - http://www.defender2.net/forum/topic58275.html - might be an interesting read before your next priority purchase Rolling Eyes Rolling Eyes
Post #675352 3rd Jan 2018 11:23am
TJH1985
Webasto would be nice Laughing
**adds to the project list**
Post #675707 4th Jan 2018 2:41pm
lightning
What about removing the viscous fan coming completely? I’ve read on forums people have done this and never had the engine overheated even when towing a caravan in France in the Summer
Post #676813 8th Jan 2018 8:46am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
If you can keep driving you might be lucky. But if you get in a traffic jam I bet it overheats. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #676839 8th Jan 2018 10:49am
