Home > Puma (Tdci) > Front washer jet |
Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142 |
Would have thought you can get a replacement nozzle quite easily, there was a post to an upgraded 5 or 6 headed replacement version that I can’t find a link to but while your fitting a new one you may as well upgrade it as the original is pretty poor
29th Dec 2017 12:57pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 381 |
Thanks..will take a look about asap.. . 2015 90 XS Santorini Black
29th Dec 2017 1:36pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
The nozzle bit pops off in freezing weather. There is a thread on the site regarding options to replace.
29th Dec 2017 1:56pm |
Thank you! 2015 90 XS Santorini Black
29th Dec 2017 2:20pm |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
The bit that pops off is factory available part and a wee drip of superglue and a tap with a hammer saves stripping the dash. Dont buy the complete nozzle and pipe as removing the part you need weakens it and it will pop off again.
29th Dec 2017 2:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Last year the complete nozzle was a fraction of the cost of the part that pops off on its own
On a Puma, you can replace the whole nozzle if you remove the centre panel of the dash (although it is a bit of a fiddle), you do not have to remove the entire dash. The 6-jet upgrade is made by Optimill and is excellent but pricey. |
29th Dec 2017 3:20pm |
THanks all.... I wasnt using any antifreeze! So that explains a lot.
Have ordered the parts and will sort in time! 2015 90 XS Santorini Black |
29th Dec 2017 4:02pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1316 |
Useful tip for everyone, thanks Blackwolf. I happened to spot the washer jet behind the centre panel last week whilst I had the panel removed for some other work I was doing. I made a mental note that it looked as though it could be replaced if needed. Good to know this is the case. |
29th Dec 2017 5:32pm |
it's easy to replace on a Puma, but idealy you do need someone to hold the jet on the outside while you do up the nut inside. I managed to do mine by temporarily holding the outer part with masking tape while i got the nut most of the way on.
29th Dec 2017 9:23pm |
Antifreeze in washers not a good idea but screenwash gets a 10 from Len. |
29th Dec 2017 9:28pm |
'screenwash' contains antifreeze.
Just like 'Coolant' also contains antifreeze. |
29th Dec 2017 9:42pm |
Different stuff. Always keep antifreeze for engine and screenwash for the washer bottle.
Antifreeze is a known paint stripper. |
29th Dec 2017 10:46pm |
Yes you're right "Coolant" is different stuff to "Screenwash" - but they both contain 'antifreeze'. Antifreeze being any substance that prevents freezing....
Antifreeze is still a valid term to use for both engine coolant and screenwash. Salt is also a type of antifreeze, but i wouldn't put that in my engine coolant or my screenwash. It's a known rust promoter.... |
30th Dec 2017 12:01am |
30th Dec 2017 12:21am |
