Home > Td5 > Break inertia switch circuit to disable Defender |
2.4 inertia switch is inside 10AS alarm i believe may be wrong
3rd Jan 2018 5:04pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
Just reading this thread with interest as seen this
https://www.landroverdefendersecurity.com/...f-2-2-tdci Wondering how easy it is to fit. Where would it fit and how would you get the wireing into the cab safely? My biggest concern is knocking the switch while driving. Especially with the location I would ideally want to fit. |
5th Mar 2018 8:49pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1072 |
Interesting. They must have read this thread
I share your safety concerns. You could use a locking switch instead. However, it has to lock in the ON postion. I have modified this http://www.mudstuff.co.uk/products/carling...k-789.html to lock in both positions (for a different purpose). Or a rotary switch. Or two switches, mounted not close to each other. Or any other kind of switch that isn't easily operated http://www.instructables.com/id/Frankenstein-Light-Switch/ |
5th Mar 2018 9:49pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
This is a mod I've been considering for my Td5 90.
I was thinking of adding a small discreet button somewhere out of the way, wired to energise a small relay fed from the ignition live to make the connection through the inertia switch, that way there is no need to switch anything off when leaving the car, just need to press the button before starting once the ignition is on. |
6th Mar 2018 5:38pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2096 |
I've sent you a PM Clive
6th Mar 2018 5:48pm |
Cheers Will, answered
6th Mar 2018 6:23pm |
Exactly why I think safety should be considered here and a cheap little switch might not be enough. It's about assessing risks. It might work ok for a long time, but if and when it fails it can be devastating. But hey, I'm German - can't help thinking that way; bloody genes... |
6th Mar 2018 10:16pm |
Changed 1 relais and the problem was solved. The buyer just didn't understand the system. Roel
7th Mar 2018 7:24pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
I don't mind admitting I do not know how you did this....any chance of a diagram ...product list..via pm if your prefer... Thanks in advance...
7th Mar 2018 9:54pm |
vulcanfreak Member Since: 05 Sep 2010 Location: suffolk Posts: 77 |
I think that the longer this thread stays in the public domain, the less effective this security feature becomes.
8th Mar 2018 7:02am |
Cats out of the bag i am afraid when there is a commercial product on the market.........I will keep my switch in place but my faith in its utility has diminished ..but i guess its one more thing for the to take a minute or so to bypass.......shhhh dont tell anyone but you could deploy the commercial product but also interupt the wire further up the chain...so when the look for the commercial product and bypass it ..the other switch kicks in.........
9th Mar 2018 1:14am |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 |
Is this the switch or just the reset? 2.2 puma engine. Click image to enlarge Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
13th Mar 2018 12:05am |
That's the inertia switch. .....
13th Mar 2018 7:09am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5162 |
does the td5 have a starter relay? Rovers have them, its a little black box with two plugs. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
14th Mar 2018 10:13am |
