Home > Off Topic > Help from any Boat People
Stripygitface
Trying to help my uncle, who has a Petrol Volvo Penta Engine in his boat, and needs to adjust the ignition timing on the distributor, which needs a clamp bolt released.
According to the manual this requires a Volvo special tool P/N 888863. The problem he has been having is getting hold of this tool, either to purchase or borrow.
Does anybody know where to get one, or a work around whereby the tool isn't needed. From what he has told me the space is very restricted and awkward to get to, hence why he has struggled so far to get something else to fit.
Post #672733 22nd Dec 2017 8:18pm
grafty99
It's basically a 90° hex head tool with a hole drilled in it. Could probably make one by machining a standard Allen key?
Here is a picture pulled from google Thumbs Up
Is that of any use? Contains dimensions of the tool too Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #672734 22nd Dec 2017 8:26pm
Stripygitface
How on earth did you find that information, he has been searching for weeks, and found nothing.
Very helpful, thank you very much.
Post #672735 22nd Dec 2017 8:29pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Get a tamper proof set of Allen keys,
That should sort it! Wink 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #672742 22nd Dec 2017 8:33pm
grafty99
No problem, just did a quick Google search with the part number and Volvo penta key words, as Ian says tamper proof Allen keys would do it. Just make sure they have similar dimensions Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672743 22nd Dec 2017 8:35pm
ian series 1
https://m.ebay.co.uk/itm/9PC-LONG-ARM-HEX-...Sw9N1V2vmd
Anything like this should do the job.
Funny enough I was googling the very same image as Grafty, but he beat me to it Thumbs Up 80" 80" 86" 88" 90"
Post #672745 22nd Dec 2017 8:39pm
grafty99
Are metric Allen keys close enough to use? As the manual says 7/32 hex Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672749 22nd Dec 2017 8:42pm
ian series 1
Your right, it would pay to get the correct size!
https://m.ebay.co.uk/itm/Bondhus-Security-...CcXyORbLPw 80" 80" 86" 88" 90"
Post #672753 22nd Dec 2017 8:57pm
grafty99
Nice one, you don't get that kind of service from your local marine engineer Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672755 22nd Dec 2017 9:02pm
Stripygitface
Thank you for all your help.
The biggest problem my uncle was having was that due to the restricted access, he can't get standard security bits in, tried cutting a few down to fit, but without being 100% sure that the trial ones were the right size, he didn't want to try and get the clamp bolt undone, and do any damage to the head, as from the way he describes its location it would most likely then be an engine out job to be able to get enough access to get the bolt out by other means.
Post #672780 23rd Dec 2017 8:10am
ian series 1
Shocked
That sounds like Volvo really thought about what they were doing with that!
By the sounds of it, it would be worth replacing with a normal bolt once you get it out. 80" 80" 86" 88" 90"
Post #672783 23rd Dec 2017 9:04am
grafty99
According to Google it was done for Californian emissions law. It has to be set at the factory and tamper proof.
Our ATV was the same. Had to drill the brass plugs out of the carb to adjust the mixture - the dealer said that if it was running poorly due to carb adjustment then it was a new carb job Shocked needless to say 5 minutes with a drill saved a few hundred quid Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672784 23rd Dec 2017 9:16am
grafty99
Just looked, the top paragraph of the picture also says why it's tamper proof Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672785 23rd Dec 2017 9:17am
grafty99
Yeah, replacing with a standard bolt may be very helpful in the future Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #672786 23rd Dec 2017 9:19am
ian series 1
Sadly you won't be able to tinker with anything in a few years, the way things are going.... Big Cry
The other day, I was explaining to a young lad at work how a points ignition system worked,
He looked at me bemused, and said it sounds way to complicated Rolling Eyes
I showed him how you would set the points, he just said "it's easier when you can just plug it in to an ECU"
And "we're all old cars like that" Laughing
A lot of two stroke equipment is now factory set, like you say.
Times a changin Rolling Eyes 80" 80" 86" 88" 90"
Post #672805 23rd Dec 2017 11:42am
