Home > Off Topic > Help from any Boat People |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4786 |
It's basically a 90° hex head tool with a hole drilled in it. Could probably make one by machining a standard Allen key?
Here is a picture pulled from google Click image to enlarge Is that of any use? Contains dimensions of the tool too 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
22nd Dec 2017 8:26pm |
Stripygitface Member Since: 16 Sep 2014 Location: Kent Posts: 79 |
How on earth did you find that information, he has been searching for weeks, and found nothing.
Very helpful, thank you very much. |
22nd Dec 2017 8:29pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Get a tamper proof set of Allen keys,
That should sort it! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
22nd Dec 2017 8:33pm |
No problem, just did a quick Google search with the part number and Volvo penta key words, as Ian says tamper proof Allen keys would do it. Just make sure they have similar dimensions 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
22nd Dec 2017 8:35pm |
https://m.ebay.co.uk/itm/9PC-LONG-ARM-HEX-...Sw9N1V2vmd
Anything like this should do the job. Funny enough I was googling the very same image as Grafty, but he beat me to it 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
22nd Dec 2017 8:39pm |
Are metric Allen keys close enough to use? As the manual says 7/32 hex 2002 90 Td5 Station Wagon
22nd Dec 2017 8:42pm |
Your right, it would pay to get the correct size!
https://m.ebay.co.uk/itm/Bondhus-Security-...CcXyORbLPw 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
22nd Dec 2017 8:57pm |
Nice one, you don't get that kind of service from your local marine engineer 2002 90 Td5 Station Wagon
22nd Dec 2017 9:02pm |
Thank you for all your help.
The biggest problem my uncle was having was that due to the restricted access, he can't get standard security bits in, tried cutting a few down to fit, but without being 100% sure that the trial ones were the right size, he didn't want to try and get the clamp bolt undone, and do any damage to the head, as from the way he describes its location it would most likely then be an engine out job to be able to get enough access to get the bolt out by other means. |
23rd Dec 2017 8:10am |
That sounds like Volvo really thought about what they were doing with that! By the sounds of it, it would be worth replacing with a normal bolt once you get it out. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
23rd Dec 2017 9:04am |
According to Google it was done for Californian emissions law. It has to be set at the factory and tamper proof.
Our ATV was the same. Had to drill the brass plugs out of the carb to adjust the mixture - the dealer said that if it was running poorly due to carb adjustment then it was a new carb job needless to say 5 minutes with a drill saved a few hundred quid 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
23rd Dec 2017 9:16am |
Just looked, the top paragraph of the picture also says why it's tamper proof 2002 90 Td5 Station Wagon
23rd Dec 2017 9:17am |
Yeah, replacing with a standard bolt may be very helpful in the future 2002 90 Td5 Station Wagon
23rd Dec 2017 9:19am |
Sadly you won't be able to tinker with anything in a few years, the way things are going....
The other day, I was explaining to a young lad at work how a points ignition system worked, He looked at me bemused, and said it sounds way to complicated I showed him how you would set the points, he just said "it's easier when you can just plug it in to an ECU" And "we're all old cars like that" A lot of two stroke equipment is now factory set, like you say. Times a changin 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
23rd Dec 2017 11:42am |
