Home > Puma (Tdci) > Starting problems
MK
Starting problems
Since a while the rig does not want to start irrespective of a warm or cold engine. Happens "randomly" and resembles a low battery situation. Tends to cranck at first but then it dies, and in the next try does nothing. Usually after another 2-3 trials or 20-30 secs is go off like nothing. I do not think it is starter selenoid.
Could this related to the immbolizer? Feature I have not studied actually.
Any clues?
MK Puma 110" SW
Post #62715 8th Mar 2011 3:16am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
iv had this before if you remove the key and lock the vehicle then unlock it it should clear its self thats what i did anyway and it worked
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #62716 8th Mar 2011 3:51am
jlprojects
Wales 2011 Defender 130 Puma 2.4 HCPU Keswick Green
Failed to start
MK, I've had the same happen to me, what I found works for me is to remove the key and activate the alarm and then de-activate the alarm. Never failed to start after that. John
Post #62728 8th Mar 2011 7:55am
Naks
check & clean MAF sensor? --
Post #62731 8th Mar 2011 8:17am
