![]() | Home > Puma (Tdci) > Starting problems |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
iv had this before if you remove the key and lock the vehicle then unlock it it should clear its self thats what i did anyway and it worked
steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
jlprojects Member Since: 10 Dec 2010 Location: now in Ireland Posts: 48 ![]() ![]() ![]() |
MK, I've had the same happen to me, what I found works for me is to remove the key and activate the alarm and then de-activate the alarm. Never failed to start after that. John
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
check & clean MAF sensor? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
