Home > Td5 > td5 making tapping noise, stops when pedal lifted
Page 2 of 2 <12
horus1970
England 1995 Defender 110 300 Tdi HT Portofino Red
cheers will try that when my road defrosts ha,
Post #670486 12th Dec 2017 12:47pm
horus1970
drove it with viscous fan removed and aux belt removed and noise still there,, making me look back at fueling now,,
i was told td5 injectors are self adjusting so im at a loss now? any ideas anyone?
Post #670903 14th Dec 2017 4:28pm
dorsetsmith
injectors are self adjusting ?
Post #670909 14th Dec 2017 5:12pm
horus1970
yeah, self adjusting, never need to adjust for lash
Post #670912 14th Dec 2017 5:31pm
dorsetsmith
if remove injectors to replace for seals and copper washer then injector slash adjust is needed Exclamation
Post #670914 14th Dec 2017 5:41pm
atakanmerdin
Kenya
I've got the exact same issue. And my harmonic damper is new sourced from turner engineering. Even tried with other "known" injectors no change. Oh and mine is also coupled with a rough idle and s little misfiring! Hot on the trail too... Let's hope!
Post #671143 15th Dec 2017 10:31pm
horus1970
yeah mine has started stuttering and taking a couple of turns in the morning to start, then its stuttery for a good while,
even when warm as soon as i dip clutch and brake it misses a beat?
Post #674440 30th Dec 2017 6:22pm
horus1970
i have given up on td5, sold it and went back to my old 300tdi, been standing for 4 months and fired up after first heat and ticked over lovely,,, loved the look of my double cab but didnt love the ecu,,,
Post #677829 12th Jan 2018 5:19am
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Mine has exactly the same .... feature ... did you manage to find the cause of it at all? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #684636 6th Feb 2018 10:21pm
atakanmerdin
Kenya
Had this issue and fixed!
1. Found ECU earth post wasn’t clean and fixed that.
2. Found two earth cables from main harness were wrongly mounted on the expansion tank mounting, connected them to engine block.
3. While there also cleaned the earth post on bulkhead behind the expansion tank.
4. Found copper washer on injector two was thinner and smaller in diameter - this fixed the rough idle.
Please note when doing the injector copper washers you MUST clean the injector seats in the cylinder head, WURTH throttle cleaner plus made up tool (think tiny bottle brush). Also don’t force the washers onto the nozzle as they do deform. Rather use the action of installing them to apply even pressure.
Engine is butter smooth again now.
Post #684702 7th Feb 2018 6:03am
Page 2 of 2 <12
