Home > Wheels & Tyres > Boost Alloys & BFG 265 75 R16 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3385 |
You should be able to go tubeless on boosts
4th Dec 2017 10:14pm |
mpald Member Since: 16 Dec 2016 Location: North East Posts: 50 |
Thank you - much appreciated.
4th Dec 2017 10:22pm |
Well, I have swapped the BFGs on to the Boosts; the only problem I now have is that the spare will not fit on the rear-door mount without resting against the rear wiper. Are there any solutions to this without welding on an extension to each of the bolts? Would a simple M12 washer or two do the job and be safe enough?
With thanks, M. |
7th Dec 2017 4:53pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 |
You should be able to space the wheel out with washers safely that's what I did to fit my 285s 2002 90 Td5 Station Wagon
7th Dec 2017 4:54pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 |
As Grafty said 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
7th Dec 2017 5:15pm |
M. |
7th Dec 2017 5:28pm |
