![]() | Home > Wheels & Tyres > Boost Alloys & BFG 265 75 R16 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3385 ![]() ![]() |
You should be able to go tubeless on boosts
mpald Member Since: 16 Dec 2016 Location: North East Posts: 50 ![]() ![]() ![]() |
Thank you - much appreciated.
Well, I have swapped the BFGs on to the Boosts; the only problem I now have is that the spare will not fit on the rear-door mount without resting against the rear wiper. Are there any solutions to this without welding on an extension to each of the bolts? Would a simple M12 washer or two do the job and be safe enough?
With thanks, M. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
You should be able to space the wheel out with washers safely
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
As Grafty said
![]() 2008 SVX 90 2000 XS TD5 90 |
M. |
