Home > Wheels & Tyres > Boost Alloys & BFG 265 75 R16
mpald
United Kingdom 2004 Defender 90 Td5 HT Keswick Green
Apologies if the following is bleeding obvious!
I am currently running the above tyres on original steel wheels, but have had trouble with tyres going flat owing to the rims which are a bit tatty.
I am thinking about putting them on Boosts; if I do, will they still need inner tubes? I presume I should also be able to do without the spacers.
Thanks for any advice.
Post #669031 4th Dec 2017 10:02pm
camelman
You should be able to go tubeless on boosts
Post #669033 4th Dec 2017 10:14pm
mpald
Thank you - much appreciated.
Post #669037 4th Dec 2017 10:22pm
mpald
Well, I have swapped the BFGs on to the Boosts; the only problem I now have is that the spare will not fit on the rear-door mount without resting against the rear wiper. Are there any solutions to this without welding on an extension to each of the bolts? Would a simple M12 washer or two do the job and be safe enough?
With thanks,
M.
Post #669567 7th Dec 2017 4:53pm
grafty99
You should be able to space the wheel out with washers safely Thumbs Up that's what I did to fit my 285s Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #669568 7th Dec 2017 4:54pm
Sulisuli
As Grafty said Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #669574 7th Dec 2017 5:15pm
mpald
M.
Post #669579 7th Dec 2017 5:28pm
