![]() | Home > Puma (Tdci) > Starter Motor Fuse !!!URGENT!!! |
td5?
fuses under drivers seat and in central panel under radio |
Organised Chaos Member Since: 20 Dec 2008 Location: Chesterfield Posts: 56 ![]() ![]() ![]() |
According to the circuit diagram, it should be a 400A mega type fuse attached to the positive terminal on the battery under the passenger seat.
mhill Member Since: 24 Jan 2010 Location: Tendring, Essex Posts: 46 ![]() ![]() ![]() |
No its a Puma.
Ah that could be the one ill stick a meeter on that one Thank you |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 ![]() ![]() ![]() |
Puma, judging by the forum and hovering over his little LR icon
![]() Starter motor solenoid fuse is 60 amp "Link 5" (not fuse 5) in the battery compartment fuse box, this also feeds the ignition switch so I would expect other items to not be working if this were blown as you state is happening. ![]() ![]() |
