Home > Puma (Tdci) > Starter Motor Fuse !!!URGENT!!!
mhill
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Bonatti Grey
Please HELP!!
Landy broke down a few weeks ago, transpires it was a blown starter motor fuse according to the dealer. I have have the same symptoms again, no power to anything & all fuses in the box under the wheel are fine as are the ones under the drivers seat. I have looked but can find no other fuse box Sad
As it wouldn't start i towed it out the way with the dumper and it bump starts fine so its defiantly some thing electrical. Its sods law that its the only 5 seater i have at the moment and need to pick family up from Stansted tomorrow.
Thanks [/quote]
Post #62486 6th Mar 2011 2:41pm
T1G UP
td5?
fuses under drivers seat and in central panel under radio
Post #62487 6th Mar 2011 2:52pm
Organised Chaos
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
According to the circuit diagram, it should be a 400A mega type fuse attached to the positive terminal on the battery under the passenger seat.
Post #62489 6th Mar 2011 3:06pm
mhill
T1G UP wrote:
td5?
No its a Puma.
Ah that could be the one ill stick a meeter on that one
Thank you
Post #62492 6th Mar 2011 3:28pm
Martin
Site Admin
Puma, judging by the forum and hovering over his little LR icon Wink
Starter motor solenoid fuse is 60 amp "Link 5" (not fuse 5) in the battery compartment fuse box, this also feeds the ignition switch so I would expect other items to not be working if this were blown as you state is happening.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #62494 6th Mar 2011 3:40pm
Martin
Site Admin
Question  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #62711 8th Mar 2011 12:24am
