Home > Puma (Tdci) > Starter Motor Fuse !!!URGENT!!! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
td5?
fuses under drivers seat and in central panel under radio |
6th Mar 2011 2:52pm |
Organised Chaos Member Since: 20 Dec 2008 Location: Chesterfield Posts: 56 |
According to the circuit diagram, it should be a 400A mega type fuse attached to the positive terminal on the battery under the passenger seat.
6th Mar 2011 3:06pm |
mhill Member Since: 24 Jan 2010 Location: Tendring, Essex Posts: 46 |
No its a Puma.
Ah that could be the one ill stick a meeter on that one Thank you |
6th Mar 2011 3:28pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 |
Puma, judging by the forum and hovering over his little LR icon
Starter motor solenoid fuse is 60 amp "Link 5" (not fuse 5) in the battery compartment fuse box, this also feeds the ignition switch so I would expect other items to not be working if this were blown as you state is happening. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
6th Mar 2011 3:40pm |
2015 D90 XS SW |
8th Mar 2011 12:24am |
