Home > Maintenance & Modifications > Puma DCPU - Rear Seats |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5859 |
Just started stripping out the DCPU for sound proofing this weekend. Trying to fold down the Puma style rear seats to make them easier to remove, but not happening. Do they work like Puma middle row seats or are they fixed? If they work the same way I can neither unlock them to fold them down or pull them forward, single side or pair. Help please. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
14th Nov 2017 2:48pm |
My mrs has the dcpu at work at the mo but I seem to remember they are bolted back in the top two corners. I need to put seat covers on hers so will have to hit this problem soon too Ray
14th Nov 2017 3:40pm |
^^^ Hello Both,
I'd heard about these brackets before beginning tackling them, but cannot for the life of me find them. Further, the seats rock slightly if pulled/pushed, so one would think the brackets are non existant or inefficient? Are they obvious? If so, they're not on mine. If I look to the left or right of the seats, between the seat edge and C Frame I cannot see anything. Are they hidden in a typically Land Roverish spot behind the seat? Invisible, inaccessible, incomprehensible? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
14th Nov 2017 4:07pm |
Mind melt from me hers is in for warranty and she has a disco sport at the mo so I can't check when she gets home sorry. Its been a long day Ray
14th Nov 2017 4:14pm |
^^^^ Mmmm, I wonder if Mrs MK1 would allow 'it's been a long day' as an excuse from you for a mind-melt? Methinks not. Suggest you take a loooong hard look at yourself and get back to me with some thoughts or advice I can use. Monsieur Le Grenadier
14th Nov 2017 4:19pm |
sorry sir. She's just rung me to let me know we should be picking it back up on Saturday (after 3 weeks) so I can have a look then. Ray
14th Nov 2017 4:28pm |
^^^ Three weeks? That was quick. Not a LR Main Dealer then Monsieur Le Grenadier
14th Nov 2017 4:29pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17478 |
IIRC (it was a long time ago that I remove mine) there is a bracket on each side of each seat back, at about the level of the rear bulkhead capping. For each bracket, there is a part which bolts to the seat, and a part which bolts to the capping, then a setscrew joins the two parts together.
I seem to recall removing the setscrew to allow the backs to tip, then deciding that the brackets (a) were useless, and (b) would require me to cut slots in the seat covers I was fitting if I wanted to reause them, so I removed the bits from the seat and the bits from the bulkhead. As far as I know there was never any other locking mechansim fitted, so operating the tipping lever at the outer lower corner of the seat should allow the seat to tip if the brackets are not fitted. If the seats wobble but don't tip, perhaps the brackets are present but loose? It was a very low-tech mechanism and not hard to spot! If you can slip a binbag or similar over the single rear seat back all the way down to the hinge, then you have no brackets. If the brackets are fitted, the binliner will get snagged on the brackets and won't gfo all the way down. |
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 |
If you peer down through the rear quarter windows you should see a bracket that lines up with one on the seat back.
Mine didnt have a bolt through but I put one in on both sides to help with the rattling. I think they are m8. If youve got some fitted the seat wont budge. Nick |
14th Nov 2017 4:30pm |
Damn that's a good idea. I'd have you with me if I ever needed to escape from Colditz. Although I believe it's a musuem with some accommodation now, so not sure why I'd be effecting an escape using a bin bag. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
14th Nov 2017 4:32pm |
Thank you all. Will take a look when it's next light. Monsieur Le Grenadier
14th Nov 2017 4:33pm |
I think that Item 27 in the picture below is the part that attaches to the bulkhead.
Click image to enlarge |
14th Nov 2017 4:46pm |
Bulkhead brackets (I can't find the part numbers or pictures of the bit bolted to the seat back that this connects to):
http://www.brit-car.co.uk/product.php/1554...t_mounting http://www.brit-car.co.uk/product.php/1554...t_mounting |
14th Nov 2017 4:53pm |
well the warranty work it's in for is actually fixing thing that they didn't do right on the last warranty trip all of which I noticed at the dealers while picking it up from being "fixed" Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Nov 2017 6:34pm |
