Home > Maintenance & Modifications > Puma DCPU - Rear Seats
Grenadier
Just started stripping out the DCPU for sound proofing this weekend. Trying to fold down the Puma style rear seats to make them easier to remove, but not happening. Do they work like Puma middle row seats or are they fixed? If they work the same way I can neither unlock them to fold them down or pull them forward, single side or pair. Help please. Big Cry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #664228 14th Nov 2017 2:48pm
mk1collector
My mrs has the dcpu at work at the mo but I seem to remember they are bolted back in the top two corners. I need to put seat covers on hers so will have to hit this problem soon too Big Cry Ray
My build thread
Post #664254 14th Nov 2017 3:40pm
They are like sw or usw except that there are addtional brackets securing the backrests to the rear bulkhead.
These brackets appear to be fitted for the sole purpose of preventing you from using the space behind and below the seat for storage, and appear to be pointless! I removed the brackets from mine within about a day of buying it - the space is far too useful to waste.
Post #664257 14th Nov 2017 3:49pm
Grenadier
^^^ Hello Both,
I'd heard about these brackets before beginning tackling them, but cannot for the life of me find them. Further, the seats rock slightly if pulled/pushed, so one would think the brackets are non existant or inefficient? Are they obvious? If so, they're not on mine. If I look to the left or right of the seats, between the seat edge and C Frame I cannot see anything. Are they hidden in a typically Land Roverish spot behind the seat? Invisible, inaccessible, incomprehensible? Whistle Monsieur Le Grenadier
Post #664263 14th Nov 2017 4:07pm
mk1collector
Mind melt from me Big Cry hers is in for warranty and she has a disco sport at the mo so I can't check when she gets home sorry. Its been a long day Embarassed Ray
My build thread
Post #664266 14th Nov 2017 4:14pm
Grenadier
^^^^ Mmmm, I wonder if Mrs MK1 would allow 'it's been a long day' as an excuse from you for a mind-melt? Methinks not. Suggest you take a loooong hard look at yourself and get back to me with some thoughts or advice I can use. Whistle Monsieur Le Grenadier
Post #664267 14th Nov 2017 4:19pm
mk1collector
Rolling with laughter sorry sir. She's just rung me to let me know we should be picking it back up on Saturday (after 3 weeks) so I can have a look then. Ray
My build thread
Post #664268 14th Nov 2017 4:28pm
Grenadier
^^^ Three weeks? That was quick. Not a LR Main Dealer then Rolling with laughter Monsieur Le Grenadier
Post #664269 14th Nov 2017 4:29pm
IIRC (it was a long time ago that I remove mine) there is a bracket on each side of each seat back, at about the level of the rear bulkhead capping. For each bracket, there is a part which bolts to the seat, and a part which bolts to the capping, then a setscrew joins the two parts together.
I seem to recall removing the setscrew to allow the backs to tip, then deciding that the brackets (a) were useless, and (b) would require me to cut slots in the seat covers I was fitting if I wanted to reause them, so I removed the bits from the seat and the bits from the bulkhead.
As far as I know there was never any other locking mechansim fitted, so operating the tipping lever at the outer lower corner of the seat should allow the seat to tip if the brackets are not fitted. If the seats wobble but don't tip, perhaps the brackets are present but loose?
It was a very low-tech mechanism and not hard to spot!
If you can slip a binbag or similar over the single rear seat back all the way down to the hinge, then you have no brackets. If the brackets are fitted, the binliner will get snagged on the brackets and won't gfo all the way down.
Post #664270 14th Nov 2017 4:29pm
Leviathan
If you peer down through the rear quarter windows you should see a bracket that lines up with one on the seat back.
Mine didnt have a bolt through but I put one in on both sides to help with the rattling. I think they are m8.
If youve got some fitted the seat wont budge.
Nick
Post #664271 14th Nov 2017 4:30pm
Grenadier
Damn that's a good idea. I'd have you with me if I ever needed to escape from Colditz. Although I believe it's a musuem with some accommodation now, so not sure why I'd be effecting an escape using a bin bag. Whistle Monsieur Le Grenadier
Post #664272 14th Nov 2017 4:32pm
Grenadier
Thank you all. Will take a look when it's next light. Monsieur Le Grenadier
Post #664273 14th Nov 2017 4:33pm
I think that Item 27 in the picture below is the part that attaches to the bulkhead.
Post #664278 14th Nov 2017 4:46pm
Bulkhead brackets (I can't find the part numbers or pictures of the bit bolted to the seat back that this connects to):
http://www.brit-car.co.uk/product.php/1554...t_mounting
Post #664280 14th Nov 2017 4:53pm
mk1collector
Rolling with laughter well the warranty work it's in for is actually fixing thing that they didn't do right on the last warranty trip Rolling Eyes all of which I noticed at the dealers while picking it up from being "fixed" Ray
My build thread
Post #664329 14th Nov 2017 6:34pm
