![]() | Home > Puma (Tdci) > Squeeky Clutch pedal |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i found it was just the spring on the back of the peddle, so a cloth behind it and some "white grease" the type that stays in foamy blobs and it was fine for 6 months, but that was my squeek, your squeek may be conpleatly different, hope this helps
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
silicone spray worked for me !
![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Hi - I had (have) the same problem.
Part of the squeak was sorted during it's 24K mile service. They applied some sort of lubricant (smells like the oil that you use to clean rifles with) in an area that I couldn't reach. This sorted the main squeak/screetch. The annoying squeak that is very persistent is down by the pedal itself. I have used WD40, lithium grease and, more recently, silicon spray. THe silicon spray did the trick - however be sure to use a rag or something to cover the area. I used a wimpy paper towel and it soaked through and spread all over the mat. Initially I thought I had a leak in the car, as the silicon got all over the place. It sorted the secondary squeak for the most part - but it still comes back every now and then. |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Thank you for the replies. I am now squeek-less.
![]() There is easy access to all the moving parts from the engine side. Just remove 6 screws to remove a small plate and it then becomes easy to lubricate all the moving parts. If anyone requires pictures please let me know and I will take some. |
pictues sounds good for the future, yes please.
Winchit Member Since: 01 Mar 2011 Location: Barnsley Posts: 9 ![]() ![]() |
I had the same problem a year back when i first brought it. i took it to the garage and they covered it under warranty if in doubt winch it out
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
I'm use to it now, on mine the noise comes and goes especially when its summer here, temperatures reach up to 48 to 52 degrees at day time
![]() '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
Hi ALl,
Here is a picture of the cover I removed. (See the 6 star screws) The front of the vehicle is to the bottom of the picture. Hope that makes sense, http://www.flickr.com/photos/9885024@N05/5505367266/ |
cheers bruce you never know when that little bit of info may come in handy.
