![]() | Home > Technical > Wiper issue. Fixed! |
capnjapseye Member Since: 21 Feb 2015 Location: Cornwall Posts: 223 ![]() ![]() ![]() |
And another thing, reading all the horror stories on here about sourcing sub standard parts, where should I go to buy genuine LR parts for the wipers system? 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Duckworthparts -site sponsor great discount
Cheers for the info
I’m on it 2015 90 Hard Top 1998 90 300Tdi - chuffed to have another one 2013 Freelander 2 - for posher trips to the shop 1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it 2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit 2010 90 Hard Top - now sold Ex mil 90 - now sold |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Ian,
Did you get the dash out in 15mins? My wiper motor has started to click. Not all the time but once running in consistent rain for 20 mins it begins .... my experience is that'll be the motor on its way. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
Ah mine also has an intermittent click (or clack). Usually worse when its only light rain, I presume because there's a little more resistance on the wiper.
When you say motor is on the way out, do you mean similar to yours with the worn circlip or should I be ordering a new mechanism before I take the dash out? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
No dramas regarding the dash, Are you sure it’s the motor making the noise, or slack in the wheel boxes? Clack clack clack..... ![]() I guess wiper issues will be quite a thing on here what with all the rain we're getting! ![]() Wanted, Forward Control Anything considered. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
Ok, I have another wiper issue and posting here to keep wiper things together, may work may not!
2016 110 xs. Front wiper arms, both do the same, they move to proper full sweep position, move back 20mm and then stop. Wiper stalk position changes have no impact and make no change. Turn wipers off, no difference. The wiper motor continues to run constantly until you manually move an arm by hand back to start position. Motor then stops, presumably park switch pushed. I am thinking its the motor shaft output that needs looking at? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Could it be as simple as the rod into the motor isint connected, so it's pushed put and can't be pulled back in, or the locating hole has worn? Cheers
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
It could be. I have had the pin that connects the gearbox to the rack shear off before. 1995 Defender 110 CSW
1971 SIIA Lightweight |
Will have a look later this am albeing well I am hoping its something really simply motor end! My experience of LRs though means it probably won't be! Cheers
