Home > Technical > Wiper issue. Fixed!
Page 2 of 2 <12
capnjapseye
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Well, a big round of applause for all those who can remove their dash in 15 minutes, I’ve just taken 1/2 a day to get mine out so that I can properly assess what’s Censored on the wiper side of things.
Next job, sort the wipers; I’m looking at new wheel boxes to start with as mine are “notchy” to say the least. Now stripping the the motor, drive, wheel boxes mechanisms.
At this rate, she’ll be up and running again some time just before we go back to BST
Really looking forward to refitting the dash Big Cry .................. 2015 90 Hard Top
1998 90 300Tdi - chuffed to have another one
2013 Freelander 2 - for posher trips to the shop
1996 300 Tdi 90 Hard Top - sold 19th June 2020 - miss it, loved it
2016 90 Hard Top - demolished Nov 2019 by young driver 3.5 times over the drug limit
2010 90 Hard Top - now sold
Ex mil 90 - now sold
Post #674664 31st Dec 2017 12:54pm
capnjapseye
And another thing, reading all the horror stories on here about sourcing sub standard parts, where should I go to buy genuine LR parts for the wipers system? 2015 90 Hard Top
Post #674695 31st Dec 2017 2:43pm
Martin
Site Admin
Duckworthparts -site sponsor great discount Smile duckworthparts  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #674727 31st Dec 2017 4:29pm
capnjapseye
Cheers for the info
I’m on it 2015 90 Hard Top
Post #674728 31st Dec 2017 4:31pm
familymad
Ian,
Did you get the dash out in 15mins? My wiper motor has started to click. Not all the time but once running in consistent rain for 20 mins it begins .... my experience is that'll be the motor on its way. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #697896 2nd Apr 2018 11:53am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Ah mine also has an intermittent click (or clack). Usually worse when its only light rain, I presume because there's a little more resistance on the wiper.
When you say motor is on the way out, do you mean similar to yours with the worn circlip or should I be ordering a new mechanism before I take the dash out?
Post #697926 2nd Apr 2018 1:43pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
familymad wrote:
Ian,
No dramas regarding the dash,
Are you sure it’s the motor making the noise, or slack in the wheel boxes?
Clack clack clack..... Rolling Eyes
I guess wiper issues will be quite a thing on here what with all the rain we're getting! Big Cry 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #697944 2nd Apr 2018 2:48pm
jst
Ok, I have another wiper issue and posting here to keep wiper things together, may work may not!
2016 110 xs.
Front wiper arms, both do the same, they move to proper full sweep position, move back 20mm and then stop. Wiper stalk position changes have no impact and make no change. Turn wipers off, no difference.
The wiper motor continues to run constantly until you manually move an arm by hand back to start position. Motor then stops, presumably park switch pushed.
I am thinking its the motor shaft output that needs looking at? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056488 6th Jan 2025 8:36pm
jst
Could it be as simple as the rod into the motor isint connected, so it's pushed put and can't be pulled back in, or the locating hole has worn? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056494 6th Jan 2025 8:53pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
It could be. I have had the pin that connects the gearbox to the rack shear off before. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #1056498 6th Jan 2025 9:21pm
jst
Will have a look later this am albeing well I am hoping its something really simply motor end! My experience of LRs though means it probably won't be! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1056516 7th Jan 2025 6:40am
Page 2 of 2 <12
