Home > Expedition & Overland > Poppy Conversion to a Camper
Page 7 of 17 <123 ... 678 ... 151617>
wyvern
No ... it is the space on top of a unit where the water tank is stored.
The area was left free to allow access to the water tank, but as the plan is to put the tank low down out side the vehicle then the new unit can go here. There is still access into the lower unit from the passenger 2nd row door.
 Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #827486 24th Apr 2020 8:55pm
wyvern
New tyres this week !
BFG ATR K2 235/85/16 - so all set for the next few years !
Fitted the new unit ! (not a perfect colour match but will redo after the lockdown) just need the latches now.
As well as painting the new unit & fitting in the vehicle, Ive been up dating the electrics with new connectors and tidying up the wiring, as well as improving the auxiliary heater out lets with a new adjustable on/off vents to warm the front of the vehicle, (pic is upside down ! )
Post #828827 1st May 2020 10:33pm
L110CDL
Nice bit of work with the new unit and the other updates Gary and those tyres look good on poppy Thumbs Up Clayton.
Keeper.
Post #829091 3rd May 2020 7:49pm
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
Great looking Land Rover, looking forward to seeing more of what you do Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #829313 4th May 2020 9:23pm
LANDROVER
LandRoverAnorak wrote:
I've got a couple of those 'eBay Chinese' lamps on the back of my 110 (floods rather than spots) and find them adequate for their intended use. They've been in place for almost two years without issue so far.
I'm aware that you can spend lots more on these sorts of lights but I struggle to see the added value, to be honest.
With the LED lights being low draw do you bother with a relay or just go direct to the switch?
I was wiring in my rear LED work lights on the 110 the other day then stopped as I could'nt decide Laughing
My 90 Challenge truck I just went without...to be honest did'nt think! 2 led spots straight to switch! Feed from live on ignition switch.
Just wondering if I should put a relay in, I have left the 90 ones on for ages winching etc and switch and wiring seem fine.
Post #834207 30th May 2020 9:32am
Mine are wired via a relay as part of the control arrangement as much as the current draw, as they're automated with the reversing light. Darren
Post #834211 30th May 2020 10:00am
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
My rear work light / reversing light is via a relay but only because the original was a standard 55w unit. Now with the new led unit it doesn’t need it in my eyes as it draws very little. When the roof was done in Germany they fitted two lights internal neither had relays and when asked he said too low draw.
Post #834215 30th May 2020 10:13am
LANDROVER
[quote="LANDROVER"]
Mine are wired via a relay as part of the control arrangement as much as the current draw, as they're automated with the reversing light.]
Thank you for your reply.
I have a separate switch on the 90. Then I can leave on when winching etc. Mine is not through reverse light though that would be handy!
Post #834216 30th May 2020 10:14am
LANDROVER
My front spot led and light bar is all through relays. Like yourself they have normal lights HID etc before so I keep thinking it probably is unnecessary.
I might just wire the switch direct. Save a bit of extra wiring and hiding the relay in the fusebox etc
Post #834217 30th May 2020 10:17am
It does also depend on the switch that you plan to use. I'm using genuine push buttons, which don't have a particularly high rating. Darren
Post #834220 30th May 2020 10:48am
wyvern
My front driving spots are via a relay as they are very bright and are independently switched and linked to the main beam selection,
The rear work light is linked to the side work light and again via a relay as the wiring was fitted by the main dealer when I bought the vehicle ... I’ve just got to move the feed to the 2nd battery and away from the ignition side of the relay so as they can be used with the ignition off.
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #834237 30th May 2020 12:26pm
wyvern
Had a weekend camping out with poppy over the weekend in dorset next to the Cern Man ... !
Nice weather to start with but got damp towards the end of the weekend ..
Post #846104 26th Jul 2020 9:17am
wyvern
Had a weekend camping out with poppy again last week with landrover overlanding friends who have the same top as we do.
It was good to see how well the top had held up after 2 yrs continual use in remote areas. No leaks or deterioration of the fabric, hinges or seals.
The zips to the side flaps seemed to be the only issue and they have been able to get arround this with velcro.
Post #846105 26th Jul 2020 9:18am
wyvern
Fitted another small level of security in the form new bonnet protectors which replace the bushes in the bonnet hinges on both our 110’s.
Bit fiddly to get the bonnet hinge lined up with the slot in the new bush, and had to be very careful not to touch the bonnet to the windscreen wiper, but once in and the ‘key’ fitted it works very well and will slow down any possible removal.
https://www.designdevelopmenteng.co.uk/sto...p208172877
Post #846119 26th Jul 2020 11:40am
Sulisuli
Great work there Gary Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #846190 26th Jul 2020 5:58pm
