Home > Expedition & Overland > Poppy Conversion to a Camper
Page 1 of 17 123 ... 151617>
wyvern
I recently took ownership of a newer 2.2 xs 110 that has been affectionately known as Poppy.
We plan to turn Poppy into an overland camper that will allow us to tour Europe and beyond.
So far some small changes have been made to start the process,
1. a new DAB/Blutooth pioneer radio - DEH-X 8700DAB, with a dual link to the aerial so as the DAB and FM can both be picked up from the standard areal.
[url] http://www.amazon.co.uk/Pioneer-DEH-X8700D...op?ie=UTF8 [/url]
2. A glove box conversion from MSS has been made and two USB charging points fitted, with 2 others below on the passenger self below as you cant have enough of these !!
[url] http://www.mobilestoragesystems.net [/url]
3. A diesel powered Planar air heater fitted in an under cubby box unit supplied from Nakatanenga. The kit is very comprehensive and includes fittings for the fuel supply and mounting of the pump and electrical connections etc. I was able to fit the unit on my own in a day. It took me longer to find the English version of the timer control instructions.
[url] http://www.nakatanenga.de/elektro/geraete-...nder?c=115 [/url]
4. Extra power to keep the starter battery safe from running flat, so found a good sized leisure battery, Hankrook XV110MF and 140 amp VSR split charge system that were both delivered speedily and duly fitted.
[url] http://www.batterymegastore.co.uk/batterie...xv110.html [/url]
& [url] http://www.simplysplitcharge.co.uk/store/i...mp;path=88 [/url]
I was able to mount both batteries into the under seat box with out any major rewiring or re-routing. The split charge was all ready wired and just needed to be connected and earthed.
I needed to move the feed for the fitted subwoofer as it came from the middle of the floor plate and that was where the heater was to go. It�s a little tight at the moment so will extend the cable to allow for some flexibility.
The under cubby unit had fittings for two more power sockets and these were linked to the auxiliary battery to allow the running of ancillary equipment such as hand held radios and LED flashing lights with the ignition off.
5. A 240 Volt inverter is going to be added to the system along the side of the under cubby unit to allow for laptop and camera battery charging. Its one we had in our previous 110 so know its reliable and suits our needs.
6. The next plan is to fit wing protectors so as I can stand on the wings when loading up canoes and bikes etc, as well as sitting on looking at the views or sitting cups of hot chocolate on. ([url] http://defenderupgrades.co.uk/product/defe...uer-plate/ [/url])
Camping side
� what are the plans for sleeping, cooking, water supply etc..
We have been looking at a lot of set ups for camping over the last few years. Our previous 110 had dormobile seats in and allowed us to use the vehicle on a day to day basis, with sleeping accommodation on two single beds when required. However my partner was finding that the seats were not comfortable after our long distance trips of 3000 miles, and wanted to have a bed that was permanently set up.
So the logical step was for a pop top roof that give us access to the bed from inside the vehicle, and fold up out the way when not needed. That way the bulky items like bedding would be up out of the way but accessible at any time.
I needed a full roof rack to carry canoes, bicycles etc. so that reduced the choices some what.
1. We found x-vision-x ([url] http://www.x-vision-x.de/product_info.php?...pdach.html [/url]) in Germany who had a poptop that fitted the bill, and were able to look at one locally. So that is now on the agenda for fitting next year.
2. Meanwhile we looked at the inside set up of the 110. With the bed in the roof that leaves all the inside area free for use. I wanted to keep the functionality of having seating for passengers on a day to day basis when we were not camping, so a removable set up was preferable.
Again a German site, Landy-Ausbu ([url] http://www.landy-ausbau.de/vollausbau.html [/url] ) came to light that made modular units that could be fitted in place of the 2nd row seats, giving me the best of both worlds.
The units have storage cupboards on one side of the vehicle stacked 3 high, a long low unit on the opposite side for sitting, a porta-potty unit that is a big bonus!! And units accessible from the 2nd row doors. [url] https://www.amazon.co.uk/Thetford-Porta-34...orta+potti [/url] The flooring board is used to provide a table in the vehicle, and doubles as a bed board as well. This is going to be useful while we wait for the pop-top to be fitted.
3. cooker � we had a fitted cooker on the previous 110 but wanted to be more flexible in this one, so have bought a portable cooker this time ([url] http://www.amazon.co.uk/PORTABLE-HEATER-DO...r+portable [/url])
with a larger camping Gaz bottle and regulator.
4. Catering equipment & sundries = knife fork spoons, kitchen knife, colander cutting board cooking pots, cups, coffee filter, tea, coffee, chocolate, salt, pepper, vinegar, we have all ready and will put into small 'really useful boxes'
5. Water management � x1 20 lrt bottle with tap. - have one ready to go but may look at a better one after the fitting of the interior.
4. Sleeping mats are on Kipmats which are nice and thick and insulated with our 'Mountain Equipment' four season qualofil sleeping bags being used for the time being
5. Additional lighting � rear work light, DRL�s, extra driving lights, inside lights we have all ready .. just got to get them fitted
6. Recovery equipment � High-lift jack, spade, strops, tow strop shackles - again all owned and to be fitted.
That�s enough to be going on with .. but will update as the conversions happen so watch this space ! Rolling with laughter Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #646830 28th Aug 2017 9:50pm
Rashers
I look forward to your updates, wyvern Thumbs Up
Looks like you have a plan. Good luck with the conversion.
Post #646840 28th Aug 2017 10:23pm
L110CDL
^^^^ same here wyvern Thumbs Up Clayton.
Keeper.
Post #646856 28th Aug 2017 11:24pm
JOW240725
Wow! Look forward to more updates and photos as things are fitted! Its nice to see you feel the 2.2 is up to the job of a long distance overlander. Thumbs Up James
Instagram @suffolk_rovers
Post #646878 29th Aug 2017 6:18am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I did wonder if this one would get a camper conversion, and I'm glad to hear it is.
Look forward to seeing how this one develops Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #646909 29th Aug 2017 9:55am
JOW240725
Just out of interest what made you go for the x-vision-x over the Alu-Cab? They look very similar or are they one of the same? TIA James
Post #647129 30th Aug 2017 9:40am
X4SKP
Now that's a Plan... Thumbs Up
Good luck wyvern Poppy looks like she's going to have an adventurous life ...
One to add to your TODO list...
 SKIP
Post #647144 30th Aug 2017 10:59am
AmadeusLV
Latvia
I was searching for my PLANAR heater manual for the control panel too.
Then i found out these guys.
Well the website says they are official europes distributors. They have manuals and all that stuff too.
Just in case you need something else.
http://autoterm-europe.com/en/shop/product...-assy-3600
Interesting project you have there, hope to see more. Thumbs Up
Post #647158 30th Aug 2017 11:46am
wyvern
Thanks Skip - I have one in pride of place all ready !!
AmadeusLV- I have found the timer hand book in English ,... it just took some time - hope that your heater is as good as mine! very pleased with it so far - so we will see how it goes in the cooler weather and when I need to run the timer to start it in the mornings ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #647182 30th Aug 2017 1:18pm
X4SKP
Post #647185 30th Aug 2017 1:57pm
AmadeusLV
Latvia
My heater is all right too. This morning in Latvia was +9 Celsius, i had instaled modem so that i dont need to get our of bed to turn it on Very Happy ( lazy , lazy , lazy )
Post #647187 30th Aug 2017 2:04pm
Rosco
Skip, I like the concept of that, although does look pricey when you consider what it actually is. Although I'm sure in the flesh the money would be seen in the storage box/kitchen.
It reminds me of a sleeping system I was given when I had a 200tdi Disco. Box frame stood in the boot, fold down the rear seat, fold the front seats forward, stand a goalpost frame behind the rear seats which linked back to the box frame with 2 or 3 bar. Overlaid with some pre-shaped boards which had been covered with a soft foam and vinyl, and hey presto one double bed.
To be honest, I only used it once as the height of it, only left about 3 feet between the top of the board and the roof. This also meant climbing into bed was quite an effort. The other downside was it effectively removed the use of the boot. However I can see the benefit of such a temporary system now. Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
Post #647509 31st Aug 2017 10:03pm
Stacey007
Hello
Some great looking mods.
While on holiday in Skye I spotted this then spotted it again (at the House of Bruar,
I should have had a chat with the owner it looked well sorted, plus they had an overland trailer...on the site. Pop up roof love the port holes. All sorted inside with t5 type interior..
Good luck with your build
Post #647515 31st Aug 2017 10:12pm
wyvern
The perils of modifications - Having successfully fitted the 2nd battery and split charge I thought it prudent to secure the batteries and wiring in a better fashion, so took everything out and looked the securing method
During this process I seem to have allowed the stater battery positive to come into contact with the battery box and short out ... this caused my hand break cable to get rather warm and melt the covering ... !!!
so lesson learnt - now have some insulation on the wall of the battery box and some spaces around the battery to prevent a re-occrance
Now sitting at the main dealers with a couple of warrantee items being looked at and a new hand break cable being fitted !!
on a plus side - batteries now safe and secure and no other damage, and 2 USB sockets fitted !! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #647583 1st Sep 2017 8:56am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Are you taking your canoe on the ferry? Gawd knows what Brittany Ferries will charge you 😳! 2010 Defender 110 Station Wagon, Santorini Black.
Post #649148 9th Sep 2017 4:51pm
