![]() | Home > In Car Electronics > Double Din Dash - Dimensions |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Just the hazard switch wiring. It was so tight either around the back or on top of the headunit I had no choice.
Bought a new connector and contacts then cut the old connector off and in line spliced the extension loom on. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Nadine90 Member Since: 07 Jan 2018 Location: CAERPHILLY Posts: 49 ![]() ![]() ![]() |
[quote="JAY BOY"]Someone told me that you need to use a hot air gun and gently melt the plastic pipe and reform it to accept the new DD system.
Same here with Pioneer Unit ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
nihwrd Member Since: 12 Apr 2012 Location: Somerset Posts: 28 ![]() |
Finally all finished, but as people have said, a proper pig to fit. Was really struggling until I realised I hadn't transferred over the metal clips from the old fascia - doh
![]() ![]() Click image to enlarge Think I might have damaged the clock cutting the corner out though as it seems to have stopped working... Nick |
