Home > In Car Electronics > Double Din Dash - Dimensions
Page 2 of 2 <12
nihwrd
Roy
Thanks, I have the same H/U so will try trimming the clock this weekend and see if that works. Still a bit worried about some of the loom lengths though, did you have to extend any looms?
Nick
Post #698674 4th Apr 2018 9:55pm
Roy5695
Just the hazard switch wiring. It was so tight either around the back or on top of the headunit I had no choice.
Bought a new connector and contacts then cut the old connector off and in line spliced the extension loom on. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #698685 5th Apr 2018 7:23am
Nadine90
Wales 1986 Defender 90 300 Tdi CSW Fuji White
[quote="JAY BOY"]Someone told me that you need to use a hot air gun and gently melt the plastic pipe and reform it to accept the new DD system.
Thumbs Up Yes the best way is to heat the pipes at the back then push in the stereo to mould the shape it needs to be, but watch you don't heat to much and puncture the plastic as seen this done before.
Post #698705 5th Apr 2018 9:27am
dgardel
Italy
Roy5695 wrote:
Depends on your headunit I suppose. My pioneer sph da 120 has quite a large unit on it and the bottom of the clock would foul on the top of the unit and prevent the facia sitting right. I removed A toblerone shape bit of plastic from the rear bottom part of the clock. Clock still works and facia fits properly.
Same here with Pioneer Unit
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #698708 5th Apr 2018 9:46am
nihwrd
Finally all finished, but as people have said, a proper pig to fit. Was really struggling until I realised I hadn't transferred over the metal clips from the old fascia - doh Embarassed
Think I might have damaged the clock cutting the corner out though as it seems to have stopped working...
Nick
Post #699215 7th Apr 2018 5:17pm
Page 2 of 2 <12
