Home > Maintenance & Modifications > Puma airbox removal
Page 1 of 3 123>
Happyoldgit
Puma airbox removal
Does anyone know the secret on how to release the air filter box from the mounting grommets? I've pulled, I've tugged, sprayed them with WD40 and still they won't shift. I've undone the mounting bracket bolts too thinking I might be able to get that out with it but the box still won't budge.
Post #4138 4th Oct 2008 3:17pm
Eduardo
Miserableolgit,
Workshop dont said too much about it
1. Release the air cleaner outlet pipe. Release the clip.
2 . Disconnect the mass air flow (MAF) sensor electrical connector. Release the wiring harness.
3 . Remove the air cleaner housing cover.
4 . Remove the air cleaner element.
Regards Eduardo
Post #4145 5th Oct 2008 1:47am
Happyoldgit
Thanks Eduardo but I got to that stage without problem. It's the filter housing itself that I want to get out but it refuses to budge even after removing its supporting bracket bolts etc.
Post #4146 5th Oct 2008 8:37am
AndrewS
It needs to be pulled up at the place where it is closest to the engine then pulled horizontally away from the wing.
Post #4151 5th Oct 2008 4:48pm
Happyoldgit
Well I've again pulled, heaved, yanked, attempted to lever and generally applied as much force as I dare and even with spraying the rubber grommets with lube the thing still refuses to budge. I think I'll end up drilling out the pop rivets that hold the upper bracket in place.
Post #4163 6th Oct 2008 10:36pm
AndrewS
Well all I can suggest is eat more for breakfast and then have a really good tug. Up and towards the engine that is.
Post #4166 7th Oct 2008 5:27am
Tim_NZ
Australia
This is what the book says:
Hope this helps.....
Tim
Post #4169 7th Oct 2008 9:31am
Happyoldgit
Many thanks for that Tim, I had overlooked the 3rd bracket fastener behind the the shock turret and obscured by mud. All sorted now.
Thanks again,
Steve
Post #4178 8th Oct 2008 11:31am
Tim_NZ
Australia
You're welcome Steve!
Tim
Post #4191 9th Oct 2008 1:23am
Edd80Inch
United Kingdom 1999 Defender 90 Td5 HT Rioja Red
In short its a basta*d 1999 90 TD5 County
1943 Ford GPW Jeep
Post #4329 26th Oct 2008 10:51pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I can't even get the top off the air box. It's a LHD and the air box is right under the right hand side wing. I spent an hour trying,but couldn't do it. Now i'm worried that when it goes to the local ford garage for it's first service (in France) they'll just not bother changing it or they'll bend the wing. Is anybody elses under the wing?
Post #4430 3rd Nov 2008 1:09am
Jim_Bean
Miserableolgit - How did you remove the housing in the end without damaging the bracket?
My 110 has just come back from the dealer with a broken bracket after removing the housing :
I'd be interested in the process you used to remove the housing without this damage.
Thanks!
Post #344449 11th Jul 2014 10:24am
Carefully drill out the rivets front under nest holding the bracket.
Re-install with short self tapping screws or more rivets, not ideal to remove on a regular basis though.
Post #344456 11th Jul 2014 10:45am
Happyoldgit
I read your posts about the bracket damage Jim Sad All it takes is a bit of patience and wiggling as the plugs are a tight fit in the rubber grommets, a bit of service spray or silicone spray applied beforehand helps them release their grip a bit. Steve.
http://forums.lr4x4.com
Post #344457 11th Jul 2014 10:49am
Jim_Bean
Thanks for the tip. So there is no way to remove the air cleaner housing from the bracket in-situ it seems.
Best to drill the rivets and remove the housing and bracket as a combined unit and refit with new rivets.
Got it.
Post #344458 11th Jul 2014 10:49am
Page 1 of 3 123>
