Home > Maintenance & Modifications > Load area seatbelt anchor bracket |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
You might find this photo helpful?
Click image to enlarge To answer your last question, the loose end of the seat belt seen below the reel mounting assembly in the photo is the part that attaches through from the inside of the tub to the captive nut on crossmember tubular bracket. |
16th Aug 2017 9:25pm |
Moash Member Since: 07 Jul 2017 Location: Perthshire Posts: 15 |
Thanks for your help.
I've also got a domed/ball shape headed bolt that came with the bracket. Any ideas what its for? Sorry if these are really basic questions. Thanks again, Scott Click image to enlarge Click image to enlarge |
17th Aug 2017 1:15pm |
That ball head bolt has puzzled me previously. It's shown on the factory parts seat belt fitting diagram as the bolt which secures the anchor end of the seat belt through the tub into the captive nut on the crossmember tubular bracket. Seems very odd as the ball part has no function for this purpose. Unless someone here knows different? Hence I suspect it may be an error in the publication? I don't see why a standard shouldered bolt wouldn't suffice?
17th Aug 2017 1:49pm |
petegoss Member Since: 19 Nov 2020 Location: Wolverhampton Posts: 7 |
How did you fit the seat belt buckles mounted to the floor?
6th Mar 2021 5:14pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
I believe the ball thing stops the seat belt lower fixing twisting round and twisting the belt.
6th Mar 2021 6:01pm |
I used take off 3rd row seats so the seat belt buckles were already attached to the side of the chairs. |
7th Mar 2021 8:40am |
