Home > Technical > EGT - How hot???
Welkman
EGT - How hot???
Hello,
In anticipation of getting my madman EMS II wired up I wanted to know what EGT I should be expecting from a tuned TD5? I have read that you want to keep them below 700 centigrade?
I have a feeling that they will be pretty high and I will need to wind the boost rod back a bit!
Post #639392 24th Jul 2017 3:56pm
bankz5152
800 is about the highest i think. Dont turn the boost down, more air = lower EGTs.
Post #639402 24th Jul 2017 4:48pm
Welkman
Ok - I will monitor it and see if the map allows decent EGTs. Its the full billet turbo and intercooler stage 3 map !
Post #639415 24th Jul 2017 5:50pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
If you're going to that expense, i'd get an EGT gauge fitted 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #639426 24th Jul 2017 6:18pm
Welkman
I am about to fit one as part of the kit. I was just asking what range is ok and what is too high.
Post #639428 24th Jul 2017 6:21pm
Kit
Proper job Thumbs Up 1993 200 Tdi 90 CSW
Post #639435 24th Jul 2017 6:44pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hmnnnnnn.....
I have one fitted to my puma 2.2 with bas 170 remap
Highway 6th gear on slope 110kmh egt can go up close to 500
In city driving never goabove 300....
Post #655252 6th Oct 2017 6:31am
pannawonica
Australia
Temperature figures given, are they pre or post turbo Tuesday fox? Thumbs Up
Post #655326 6th Oct 2017 12:31pm
tuesdayfox
Hi mate
They are post turbo.
I just used the blank plug to install the egt (as per Madman instructions
The plug was used for dpf sensor but luckily we don't have these...
What are your readings?
Post #655329 6th Oct 2017 12:43pm
jst
500 is no worries.
my tgv is tunned a fiar bit and will top 700 if you hold it in the gears, just drive to the EGT gauge! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #655400 6th Oct 2017 4:08pm
pannawonica
Australia
My Alive down pipe doesn't have a facility for fitting a EGT probe. However a good remap and all the usual mods from what I understand should mitigate high prolonged EGT,s. That been said I would still like too have one fitted! The ultraguage gives me the CHT readings and a tell tale of when too ease up. Thumbs Up
Post #655543 7th Oct 2017 3:44am
More gauges, more problems Wink
Post #655545 7th Oct 2017 6:49am
jst
^^^ yep Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #655546 7th Oct 2017 7:21am
